29487 Discussions
THE error:If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. [A]
vickyxin
Hi,all
I had compuiled for WRF model with intel fce 10.1.but there is a error in compiling process:If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. .Because the WRF program is too big ,so i wrote a simlified program to test.
module test
integer,pointer::a(:)
contains
subroutine ff(a)
integer a(100)
end subroutine
subroutine f
call ff(a(2))
end subroutine
end module test
ifort test.f :
How can i do if i dont wanna to modify the program (because the WRF souce codes are very big)?Can i use some compile option?
The code you have posted is not legal Fortran. If A was not a POINTER, it would be ok, but there is no "sequence association" for POINTER arrays (since they can be discontiguous.)
There is no compile option to avoid this error - you will have to correct the code.
My understanding is that current versions of WRF do compile with Intel Visual Fortran, though I am not familiar with the details.
vickyxin
Thank you for your reply.
There are some places in WRF(module_dm.f,module_domain.f,and so on ) which are using the codes like the example. And the same codes can be compiled sucessfully with intel fortran compiler 9.0 .
I just saw the netpage:http://support.intel.com/support/performancetools/sb/CS-028607.htm. Iplan todownload the correspondent version of WRF and Fortran compiler, wish suceed.
9.0 had a bug in that it did not test for this error condition.
ltaylor934
How would you *correct* the sample code as given in the thread?
At present, all I get is a message that my code is wrong, and I have no guidance about what is right.
By the way, I interpret
integer, pointer :: a(:)
to be a pointer to an array, not an array of pointers. Why would it not be contiguous?
LAT
To correct this example, I would make A an ALLOCATABLE instead of POINTER and change the declaration of the dummy argument A of FF to be (*) rather than (100).
You are correct that this is a pointer to an array but you could define the pointer as pointing to a non-contiguous slice of an array, for example:
A => B(1:10:2)
Because this is possible, "sequence association" is not available for pointer arrays. Since it is NOT possible with allocatable arrays, sequence association is allowed.
van_der_merwe__ben
New Contributor II
I have to compile some old code, and I got this same error on this code:
INTERFACE
SUBROUTINE GETBCPRESSURE(I,V)
!DEC$ ATTRIBUTES DLLEXPORT, ALIAS: '_getbcpressure' :: GETBCPRESSURE
!DEC$ ATTRIBUTES VALUE :: I
!DEC$ ATTRIBUTES REFERENCE :: V
INTEGER :: I
REAL :: V(*)
END SUBROUTINE
END INTERFACE
REAL :: PRESSURE
CALL GETBCPRESSURE(BCINV,PRESSURE)
It completely baffled me, but I managed to "fix" it as follows:
REAL, ALLOCATABLE :: PRESSUREA(:)
ALLOCATE(PRESSUREA(2))
PRESSUREA(1)=PRESSURE
CALL GETBCPRESSURE(BCINV,PRESSUREA)
PRESSURE=PRESSUREA(1)
Dunno how a single real could cause this error, but oh well.
TimP
On the platform I learned on, pointer-to-scalar was incompatible with pointer-to-array. If I remember correctly, the latter had an additional level of indirection. Fortran rules support such platforms. At your own risk, you could turn off the checking and use non-portable code, if your intention is to make it break on those platforms while ignoring the problem on your favorite one.
mecej4
Instead of placing an array element in place of the expected array argument, provide an array slice:
[fortran]        module test
        contains
        subroutine ff(a)
        integer a(100)
        end subroutine
        subroutine f
                call ff(a(2:))
        end subroutine
        end module test
[/fortran]
I have no idea whether the actual subroutine (rather than this extract) will use only the slice that is given to it or will try to use the full array. The latter will cause an error, and the former would require that information on the length of the array slice be made available to the subroutine by the caller in some acceptable way.
