29651 Discussions
TRANSFER function produces wrong result
afshar__yaser
(ifort version 16.0.1 on OSX L Capitan 10.11.3) using Transfer function in this version produces wrong results:
program test
implicit none
integer :: i
i=-2098177
print*,i,transfer(i,1_8)
print'(b32.32,10x,b64.64)',i,transfer(i,1_8)
end program test
    -2098177              -2098177
11111111110111111111101111111111          1111111111111111111111111111111111111111110111111111101111111111
while using the older version (ifort version 15.0.2) produces the correct results
    -2098177           4292869119
11111111110111111111101111111111          0000000000000000000000000000000011111111110111111111101111111111
mecej4
All the results that you listed are in agreement with the designation "processor dependent", and code that assumes a particular result is not portable code.
The next question is, "which result would most users want to see as a result of transferring a negative integer to a wider destination? In assembly language terms, after the source has been loaded into the EAX register, should we use a MOVZX or a MOVSX? Personally, I would like the sign to be preserved. As long as we are using 2-complement representation, I think that what IFort 16.0 is doing is preferable.
Let us see what others have to say.
mecej4
The Fortran standard says this about the TRANSFER intrinsic function:
If the physical representation of the result is longer than that of SOURCE, the physical representation of the leading part is that of SOURCE and the remainder is processor dependent.
I interpret "leading part" to mean "in little-endian byte order" rather than in "leading in printed text form".
afshar__yaser
Yes, I agree with the standard, but this is not the case as the integer value is (-2098177). Plus there is the difference in intel FORTRAN versions as I mentioned.
This looks like a bug, not standard misinterpretation.
mecej4
Please try -1 in place of -2098177 on line-4 of your test program, and reevaluate your expectations.
afshar__yaser
Please look at this:
program test
implicit none
integer :: i
integer(8) :: j
i=-1
j=transfer(i,1_8)
print*,i,j
end program test
          -1                    -1
          -1            4294967295
(gcc version 5.2.0)
          -1           4294967295
(ifort version 14.0.0)
          -1            4294967295
(pgfortran 15.9-0 64-bit target on x86-64 Linux)
           -1               4294967295
You can see the difference in intel versions also with other compilers. As if the transfer function in this new version is working like (INT(-1,8)).
mecej4
The original answer holds - the result of what you are doing is "processor-dependent" which means that the implementation can do anything it wants. We have made changes in TRANSFER in the past and it may be that the way we handle this case changed. Both results are "correct" - one may be not what you want, but that's not a compiler bug.
We have an intrinsic function ZEXT that does the zero-extension, but it is non-standard. TRANSFER is not what you want for this purpose.
jimdempseyatthecove
You can get sign preserved with
AnI8 = AnI4
If TRANSFER performs sign extension (which is not printed order by the way), then you do not have a means of performing unsigned extension. Which complicates performing multi-precision arithmetic without using a unioned structure of AnI8 and AnI4. Personally I use the UNION because it is unambiguous as to your intentions.
Jim Dempsey
