TYPE, BIND(C, NAME= not compiling
Norman_K_
What is wrong with the following?
module mod_dill
    use, intrinsic :: iso_c_binding, only: c_char
    implicit none; private
    public :: ipaddr
    type, bind(c, name='dill_ipaddr') :: ipaddr
        character(c_char) :: address(32)
    end type ipaddr
end module mod_dill
! ------ Build started: Project: test_tcp, Configuration: Debug|x64 ------
! Compiling with Intel(R) Visual Fortran Compiler 19.0.5.281 [Intel(R) 64]...
! mod_dill.f90
! mod_dill.f90(8): error #5082: Syntax error, found ',' when expecting one of: )
! mod_dill.f90(8): error #5082: Syntax error, found '::' when expecting one of: , <END-OF-STATEMENT> ;
! mod_dill.f90(8): error #6274: This statement must not appear in the specification part of a module.
! mod_dill.f90(9): error #6236: A specification statement cannot appear in the executable section.
! mod_dill.f90(10): error #6274: This statement must not appear in the specification part of a module.
! mod_dill.f90(8): error #6404: This name does not have a type, and must have an explicit type.
! mod_dill.f90(8): error #6632: Keyword arguments are invalid without an explicit interface.   [NAME]
! mod_dill.f90(8): error #6404: This name does not have a type, and must have an explicit type.   [BIND]
! mod_dill.f90(8): error #6404: This name does not have a type, and must have an explicit type.   [IPADDR]
Merry Christmas
N
FortranFan
@Norman K.,
Merry Christmas.
As explained by Andrew, NAME= clause is not an option in a derived-type definition such as with your 'ipaddr' type.
Did you mean to have NAME= clause in a type declaration of a de facto 'global' object as shown below?
module mod_dill
    public :: ipaddr
    type, bind(C) :: ipaddr
    end type ipaddr
    type(ipaddr), bind(C, name='dill_ipaddr'), public, save :: dill_ipaddr !<-- NAME= ok here
end module mod_dill
andrew_4619
Remove ", name='dill_ipaddr'"  there is no syntax in TYPE to make an alias name in standard Fortran.
FortranFan
@Norman K.,
Merry Christmas.
module mod_dill
    public :: ipaddr
    end type ipaddr
end module mod_dill
Norman_K_
so...
"Bind with name" an instance, but not a whole class
Makes sense,
Thanks both
Merry Christmas
N
