29386 Discussions
Tabify does not work in VS2010 with fixed form files.
JAlexiou
In VS2008 with a fixed form file (.for) if I select multiple lines and press the [Tab] key I get the expected indentation behavior (Tabify).
VS2008 - Tab
The same is not true in VS2010 with the exact same file and sequence of actions. The [Tab] key inserts a tab character destroying my source file.
VS2010 - Tab
This is a big problem as reformatting code may accidentaly remove lines if not caught and undone. It takes two `Ctrl-Z` key presses to undo this action, and then the indentation has to be done in a line by line bases. This is Extremely annoying and I hope there is a switch or setting somewhere that fixes this issue.
PS. I have "Intel Visual Fortran Compiler XE 12.1.4.325 [IA-32]"
Anonymous66
Valued Contributor I
Thank you for letting us know about this issue. I have escalated it to the developers. The issue number is DPD200182225. I will post any updates I receive on this issue here.
Anonymous66
A fix has been found for this issue. We are planning to include it in the next update which is currently scheduled for late June.
JAlexiou
So is there a link to the official issue tracking post (DPD200182225) where we can contribute and monitor progress?
Anonymous66
No, but I will update this postwhen the fix is available. We are currently planning to include it in the next release which is scheduled for late June.
Annalee
Anonymous66
Hello John,
This issue has been fixed in the latest update, Intel Visual Fortran Compose XE 2011 update 11 for Windows*.
Annalee
Intel Developer Support
* Other names and brands may be claimed as the property of others.
