29344 Discussions
Test_ExitNoPersist builds and runs using IFORT but gets build errors using IFX
rivkin__steve
New Contributor II
Test_ExitNoPersist builds and runs using IFORT but gets build errors using IFX.
A test driver, subroutine, and project files are attached.
First build it using IFORT and run it. Then try to build it using IFX.
rivkin__steve
New Contributor II
The Test_ExitNoPersist program compiles, links, and runs using IFX and oneAPI 2024.0.2.
Barbara_P_Intel
This reproducer uses QuickWin. Did you try the workaround from Steve in this thread.
I don't see a zip file with the VS solution/project. Please upload that.
rivkin__steve
New Contributor II
Attached are the project files for the IFORT build and the IFX build with the only change being: General > Use Compiler > IFX
rivkin__steve
New Contributor II
The recent update using BaseKit v2023.2.0.49396 resolved the issue with exit_no_persist.
rivkin__steve
New Contributor II
