29413 Discussions
The'Windows Forms Designer Package' package did not load correctly.
Rasoul_K_
REcently I am facing following error
Micorsot Visual Studio
The problem may have been caused by a configuration change or by the the installation of another extension.
It has a yes and no bittom to show the message next time or not.
Although it will be good know the reason and and solve to avoid itm but more than that I am anxious if it could affect the output of my runs.
Apparently it is not affecting the output.
This is part of Visual Studio that is not used by Fortran.
Rasoul_K_
Before, I didn't get this error message.
Is it possible that it affect the Fortran code output?
It will have zero effect on your Fortran code.
Rasoul_K_
Before installing VS 2010, I had installed VS 2008.
Few days ago I uninstalled VS 2008 as I don't use it.
Is it possible that this error message comes from this action?
Is the output will be OK?
I don't know what causes this error.  The next time it comes up tell Visual Studio to disable loading that package. Then forget about it.
