29487 Discussions
The flags "-openmp" and "-tcheck" can't be used together, but what good are they apart?
ymost
I have a very simple program that uses OpenMP. I want to analyze it with the Intel Thread Checker, which I have installed. The only problem is, the compilation flag "-openmp" cannot be used together with the flag "-tcheck". When I use them together I get the warning: "thread checking compilation disables optimization", and the "-openmp" flag is ignored. I just couldn't believe this, because without the "-openmp" flag the program is not parallel, and so there is no need to use the Thread Checker. If I compile it only with the "-openmp" flag and without the "-tcheck" flag, the program works fine with several parallel threads, but I can't analyze it with the Thread Checker.
Can anyone tell what's going on here?
BTW, I'm using Intel Fortran Compiler version 11.0, build 20080930, and Intel Thread Checker version 3.1.
TimP
As the message tries to tell you without too much verbosity, -tcheck only enables a syntax checking mode, which actually takes longer than a serial run. If you want to check a production threaded build of a "very simple program," you can try the dynamic instrumentation mode of thread checker. That is even slower running than the -tcheck mode.
There was an 11.0 build which didn't include the OpenMP debug library which is required for -tcheck. I think it was earlier than the one you mentioned.
If you make a dynamic linked OpenMP build with -g but not -tcheck, and it doesn't use the debug library by default, you could set the debug library in LD_PRELOAD.
You didn't say anything about using OpenMP syntax features which Thread Checker doesn't support under -tcheck, so I'm assuming that's not the objection.
I may not have understood your objection entirely.
