29276 Discussions
The number of subscripts is incorrect
harsha_vss
I am attaching the basic code. I'm a beginner in Fortran. Can anybody help me with this error?
program check
implicit none
real(8) :: y(2,2)
integer :: i,j
real(8), dimension(2,2) :: u, deep
real(8) :: x = 100 , z = 50
do i = 1,2
do j = 1,2
y(i,j) = i+j
end do
end do
u = deep(x,y,z)
end program check
function deep (x,y,z) result (t)
implicit none
real(8) :: x , z , h
real(8), dimension (2,2) :: y, t
!real(8), dimension (2,2) :: deep
integer :: i,j
h = x+z
t = h*y
end function
Arjen_Markus
Well, it is quite simple: the program contains a declaration of an array deep which has dimension 2. Later in the program you use it with three indices - you probably meant to use the function deep that appears after the program itself, but the compiler first sees the declaration and the incorrect use of the array.
Here is my correction of the program:
module deepfunc
    implicit none
contains
    implicit none
    integer :: i,j
    h = x+z
    t = h*y
    end function
end module deepfunc
program check
    use deepfunc
    implicit none
    real(8) :: y(2,2)
    integer :: i,j
    do i = 1,2
    do j = 1,2
    y(i,j) = i+j
    end do
    end do
    u = deep(x,y,z)
end program check
By putting the function in a module you achieve that the compiler knows that is a function, what results it gives and what the arguments are.
You could achieve that in a number of ways, but using modules is a robust way to make sure the compiler can check things.
Arjen_Markus
module deepfunc
    implicit none
contains
    implicit none
    integer :: i,j
    h = x+z
    t = h*y
    end function
end module deepfunc
program check
    use deepfunc
    implicit none
    real(8) :: y(2,2)
    integer :: i,j
    do i = 1,2
    do j = 1,2
    y(i,j) = i+j
    end do
    end do
    u = deep(x,y,z)
end program check
harsha_vss
mecej4
When a function is used that does not return a scalar value, among other situations, the rules of the language require that an interface be available to the compiler. Arjen showed you one way of providing that interface. Another way is to make the function a contained function:
program check
implicit none
real(8) :: y(2,2)
integer :: i,j
do i = 1,2
do j = 1,2
y(i,j) = i+j
end do
end do
u = deep(x,y,z)
contains
implicit none
integer :: i,j
h = x+z
t = h*y
end function
end program check
harsha_vss
Thanks, Mecej4! I understood that concept now.
jimdempseyatthecove
Implicit in Markus and mecej4's postings is that you develop an understanding as to if your function deep is intended to be used only by a single calling procedure .OR. by multiple calling procedures.
In the case of single calling procedure, then the contained procedure method may be preferred.
In the case of multiple calling procedures .OR. potential re-use by you in some future project, then use the module contained procedure (and make the module a separate source file).
We (this forum) have many experienced programmers willing to help beginners learn good programming techniques.
Jim Dempsey
