29235 Discussions
The parallel do is not faster than the serial do.
eliopoulos
I have created a FORTRAN program and I would like to make it faster. So, I used the parallel do for my main loop. Although the CPU works at a much higher rate, the program is not faster, whatever number of threads I use. The speed also does not really change when I change the number of threads. Any advise?
jimdempseyatthecove
It would help if you would show the code.
There could be any number of reasons why your code isn't running any faster.
The usual culprits are:
1) Calling support routines that serialize (contain critical section) the code. For example calling RAN (or other random number generators), performing I/O, heavy memory allocations, among others
2) Too short of runtime for the application to amortize the startup
3) Using many more threads than is practical for a small application.
4) Oversubscription of threads
Without seeing the code (or a good sketch of the code) makes it difficult to offer suggtestions.
Jim Dempsey
eliopoulos
I would not like to share the code in public. Could you provide an e-mail address?
jimdempseyatthecove
