Hi all,
I have the following code:
implicit none
real*8,pointer::test(:)=>null()
call allocatetest(test)
end
subroutine allocatetest(test)
implicit none
if(associated(test))deallocate(test)
allocate(test(100))
test=0.d0
end subroutine
Could anyone tell me how to modify the code to let it also work in release mode? My working envorinment is: Windows XP+VS.net2005+IVF10
Zhanghong Tang
You need to make an explicit interface for allocatetest visible to the main program because the argument is an assumed-shape array and also because it is a pointer (either of these would trigger the requirement.) I'm astonished it works even in debug mode.
The simplest fix is to structure the program like this:
... call allocatetest (test)
contains
subroutine allocatetest (test)
end subroutine allocatetest
end
Making allocatetest a contained procedure provides the explicit interface.
For more information, see my article Doctor Fortran Gets Explicit.
contains
end
Hi Steve,
Thank you very much for your kindly reply. It can work now.
Zhanghong Tang
Oh, and compiling with /gen-interface and /warn: interface would have told you about this. These are now on by default in newly created VS projects in 10.0.
Thanks again! But I just work in 10.0 version. Maybe I need to update to 10.0.26?
Zhanghong Tang
Works in 10.0.025 for me:
C:Documents and SettingsSteve>ifort /gen-interface /warn:interface t.f90
Intel Visual Fortran Compiler for applications running on IA-32, Version 10.0
Build 20070426 Package ID: W_FC_P_10.0.025
Copyright (C) 1985-2007 Intel Corporation. All rights reserved.
t.f90(5) : Warning: The procedure has a dummy argument that has the ALLOCATABLE,
ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute. Required explicit interface is missing from original source. [TEST]
