29300 Discussions
The same real kind for EM64T & IA-32?
Intel_C_Intel
The following code is supposed to print the same output when compiled for IA-32 and ran on IA-32 in comparison to the same code compiled for EM64T and ran on EM64T processor?
integer , parameter :: sp = selected_real_kind(p=6)
integer , parameter :: dp = selected_real_kind(p=15)
integer , parameter :: qt = selected_real_kind(p=18)
print*, sp, dp, qt
double precision is not supposed to be kind 4 (and not 8) on 64 bits machines running IFORT? I was thinking if this last question has something to do with the fact that quad precision (kind 16) operations still has a BIG performance impact on EM64T processors. Please help me to understand why quad is not double and double is not single with EM64T! TIA,
Bernhard.
The 64-bit aspect of EM64T has to do with the virtual address size and does not change the default sizes of reals and integers.
Yes, REAL(16) is slow on EM64T because it is software-emulated.
Intel_C_Intel
Why REAL(16) is software-emulated? Is this a registers' size (hardware) limitation? There is no 128-bit registers on EM64T processors? Thanks again,
Bernhard Enders.
There are no REAL(16) instructions in the IA32/EM64T architecture. Not on Itanium either. Only single and double precision. That's the way it is in pretty much every currently used architecture. REAL(16) is supported by calls to software routines inserted by the compiler.
IBM has an odd implementation where they use two doubles with offset exponents. It's fast but it isn't a uniform type and doesn't give you extended range, so it's useless for a lot of what people use higher precision types for.
