29279 Discussions
The type of the actual argument differs from the type of the dummy argument
davidgraham
I'm getting the following error - I cannot see why as the definitions look the same.
Error 1 error #6633: The type of the actual argument differs from the type of the dummy argument. [PT]
The definition of the subroutine is as follows - I have only included part of it as the problem is with 'pt'.
subroutine TriSlopeSym (sym,pt,X4,Y4,Z4,sfx,brgsym)
type enhType
integer*4 e,n,h
end type
type (enhType) pt(3)
The definition of the call is as follows - I have only included part of the code
type enhType
integer*4 e,n,h
end type
call TriSlopeSym (sym,pt,X4,Y4,Z4,sfx,brgsym)
Arjen_Markus
It looks as if you have literally repeated the definition of the enhType derived type. The Fortran standard dictates that these are nevertheless to be considered two _different_ types. Hence the message.
What you should do is put the definition of enhType in a module that you use anywhere that you have such variables.
Arjen
davidgraham
Arjen,
Thanks, I added them to a module and it worked fine.
David
Arjen_Markus
You're welcome
Arjen
