This array or function or substring is invalid in constant expressions. [C_SIZEOF]
Long_Qu
i want to compute the size of an interoperable type and register its value into an integer parameter, here is the code
module m_constant
  use, intrinsic :: iso_c_binding
  implicit none
  type,bind (c) :: t_mytype
     integer(kind=c_int) :: a
     integer(kind=c_int) :: b
     integer(kind=c_int) :: c
     real(kind=c_double) :: d
  end type t_mytype
  type(t_mytype), private :: tmp_mytype
  integer,parameter :: MYTYPE_CSIZE = c_sizeof(tmp_mytype)
end module m_constant
program test
  use m_constant
  use,intrinsic :: iso_c_binding
  write(6,'(a,i4)') 'my type csize',MYTYPE_CIZE
end program test
The compiler ifort 17.0.1 can not compile the code and show:
qu@debian:~/Desktop/test/test_csize_of$ ifort test.f90
test.f90(16): error #6259: This array or function or substring is invalid in constant expressions.   [C_SIZEOF]
I test also on a gfortran 5.2.0, i get MYTYPE_CIZE=24, and everything seems OK.
Is that a compiler bug ?
Steve_Lionel
Not a bug, but a feature of Fortran 2008 that is not yet implemented.
JVanB
Valued Contributor II
There is a possible workaround:
module M1
   use, intrinsic :: ISO_C_BINDING
   use, intrinsic :: ISO_C_BINDING, only: nothing=>C_SIZEOF
   implicit none
   private nothing
end module M1
module M2
   implicit none
   intrinsic SIZEOF
end module M2
module ISO_C_BINDING_1
   use M1
   use M2, only: C_SIZEOF=>SIZEOF
   implicit none
end module ISO_C_BINDING_1
module M3
   use ISO_C_BINDING_1
   implicit none
   type, BIND(C) :: T
      integer(C_INT) i
      real(C_DOUBLE) x
   end type T
   type(T), private :: T1
   integer, parameter :: Tsize = C_SIZEOF(T1)
end module M3
program P
   use ISO_C_BINDING_1
   use M3
   implicit none
   write(*,'(*(g0))') 'Tsize = ',Tsize
end program P
Then you would have to change ISO_C_BINDING to ISO_C_BINDING_1. With gfortran, the distinction between the INTRINSIC and NON_INTRINSIC versions of module ISO_C_BINDING means that you don't need to rename to ISO_C_BINDING_1, but of course gfortran has already implemented this feature of f2008 anyhow, so this workaround isn't necessary in that case. Later, when ifort gets around to supporting this f2008 feature, you could rename ISO_C_BINDING_1 back to ISO_C_BINDING and get rid of module ISO_C_BINDING_1.
jimdempseyatthecove
RO,
Excellent!
You might add:
!DIR$ IF DEFINED(__INTEL_COMPILER)
!DIR$ ELSE
!DIR$ ENDIF
or something like that.
Jim Dempsey
FortranFan
Repeat Offender wrote:
There is a possible workaround: ..
Why go through all that and employ a non-standard feature of SIZEOF when the Fortran standard also offers STORAGE_SIZE and is supported by Intel Fortran.
module m_constant
   use, intrinsic :: iso_c_binding, only : c_int, c_double, c_sizeof, c_size_t
   use, intrinsic :: iso_fortran_env, only : character_storage_size
   implicit none
   end type t_mytype
   integer(c_size_t), parameter :: MYTYPE_CSIZE = c_sizeof(tmp_mytype)
   ! if size desired in bytes, use named constant from ISO_FORTRAN_ENV to tranform the result in bits
   integer, parameter :: MYTYPE_SIZE = storage_size(tmp_mytype)/character_storage_size
program test
   use, intrinsic :: iso_fortran_env, only : output_unit
   use m_constant, only : MYTYPE_CSIZE, MYTYPE_SIZE
   write ( output_unit, "(*(g0))") "MYTYPE_CSIZE = ", MYTYPE_CSIZE
   write ( output_unit, "(*(g0))") "MYTYPE_SIZE = ", MYTYPE_SIZE
   stop
end program test
Since gfortran supports both, here's the execution output using that compiler:
MYTYPE_CSIZE = 24
MYTYPE_SIZE = 24
