This changes everything!
FortranFan
module m
   implicit none
   private
   type, public :: t
      private
      integer, allocatable :: m_i(:)
   contains
      private
      procedure, pass(this), public :: set => set_t
      procedure, pass(this), public :: get => get_t
   end type t
   interface
      module subroutine set_t(this, iarr)
         class(t), intent(inout) :: this
         integer, intent(in)     :: iarr(:)
      end subroutine set_t
      module function get_t(this) result(msg)
         class(t), intent(in) :: this
         !.. function result
         character(len=size(this%m_i)) :: msg
      end function get_t
   end interface
end module m
submodule(m) sm
contains
      this%m_i = iarr
      return
      !.. function result
      integer :: i
      forall (i=1:size(this%m_i)) msg(i:i) = achar(this%m_i(i))
      return
   end function get_t
end submodule sm
program p
   use m, only : t
   type(t) :: foo
   integer, parameter :: im(78) = [ 72, 101, 108, 108, 111, 44,   &
                                    32, 87, 111, 114, 108, 100,   &
                                    33, 32, 32, 83, 117, 98,      &
                                    109, 111, 100, 117, 108, 101, &
                                    115, 32, 97, 114, 101, 32,    &
                                    104, 101, 114, 101, 33, 10,   &
                                    84, 104, 105, 115, 32, 99,    &
                                    104, 97, 110, 103, 101, 115,  &
                                    32, 101, 118, 101, 114, 121,  &
                                    116, 104, 105, 110, 103, 33,  &
                                    10, 84, 104, 97, 110, 107,    &
                                    32, 121, 111, 117, 44, 32,    &
                                    73, 110, 116, 101, 108, 33 ]
   call foo%set(im)
   print *, foo%get()
   stop
end program p
Hello, World!  Submodules are here!
Thank you, Intel!
Press any key to continue . . .
rase
What's exactly the problem or the question?
Lorri_M_Intel
I think he's happy (at least, that's how I'm reading it! :-) )
           --Lorri
mecej4
The four-line pseudo program output in #1 explains the post. Finding true love reciprocated can induce what Dr. Spock would call "irrational responses". See his recent post, https://software.intel.com/en-us/forums/topic/391387 .
For a description of sub-modules, please see http://fortranwiki.org/fortran/show/Submodules .
FortranFan
The program output in the original post is not pseudo, it's actual!  Using 16.0 beta.  I attached the zip file in case anyone else wanted to review it with Visual Studio 2012/2013.
Dr Fortran has urged patience previously on this front and this shows good things do come to those who wait!  Kudos to Intel Fortran team for this major achievement.
