29632 Discussions
Threadprivate common data doesn't work with '-openmp-threadprivate compat' flag
ymost
I have an old Fortran program which uses common data blocks, and I need to use it with my new code. My new code uses OpenMP, and because of a compiler bug in array pointers which are threadprivate (see this thread) I use the '-openmp-threadprivate compat' flag. The problem is this flag causes a bug with threadprivate common data blocks. Consider the following test program, which is made of three files. First is 'iblock.com':
[plain]integer :: inum
save/iblock/
common/iblock/inum
!$omp threadprivate(/iblock/)[/plain]
Now 'bdata.f90':
[plain]black data bdata
include 'iblock.com'
data inum/7/
end[/plain]
Lastly 'test.f90':
[plain]program test
write(*,*) inum
end program test[/plain]
I have compiled this test program with the Intel Fortran compiler (version 11), with the '-openmp-threadprivate compat' flag (and the '-openmp' flag of course), and it printed 0 (instead of 7). When the threadprivate directive is removed, it works correctly (prints 7). Without the '-openmp-threadprivate compat' flag, it works correctly anyway, even with the threadprivate directive present.
Can anyone help?
Lorri_M_Intel
Put your block-data object file first in the link line.
As a totally simplistic explanation:
It seems thatthread-local-storage variables (the implementation behind the openmp_threadprivate=compat switch) work on a first-found basis.
openmp_threadprivate=legacy put the variables into "normal" Fortran COMMON storage, which merges all the declarations.
- Lorri
Kevin_D_Intel
Sorry for the delayed reply. I will inquire with the developers who suggested the earlier work around and update the thread when I know more.
Martyn_C_Intel
This looks like a bug. However, there are some limitations to the gcc-compatible implementation of threadprivate, that's why the default remains "legacy", though I don't think they should play a role here. This has been escalated to the compiler developers, we'll let you know what they conclude.
Martyn
Lorri_M_Intel
- Lorri
jimdempseyatthecove
- Lorri
Whew! That seems like a land mine.
The IVF documentation needs highlight this in the section relating to thread private data (not elsewhere such as an old FAQ).
From my understanding of the IVF documentation, when a new thread is created, thread private data from the master thread is copied into the thread private data of the new thread. Apparently this is not so.
Jim Dempsey
Lorri_M_Intel
Yeah, one of the things that we're discovering is how different threadprivate: compat and threadprivate:legacy are, and yes, we hope to improve the documentation, and possibly do some KB articles on this.
Really, we don't like landmines either :-)
- Lorri
