29386 Discussions
Threads with > 25 posts not showing "Next Page"
Les_Neilson
Valued Contributor II
Threads with more than 25 posts/replies are not showing the option to go to the next page after the 25th entry.
For example : the thread "several outputs on the same line" which says it has 26 replies.
Les
I see the buttons in IE6 and Firefox 3. Which browser are you using?
TimP
Next shows up in Firefox, Epiphany, Konqueror, and Opera, the latter 3 being versions served by linux online update servers, and the first being the 3.0.6 from Firefox update server.
As reported subsequently, Next is missing from the display of IE7 running on XPXP3.
Les_Neilson
I am using IE 7
I've just checked again and neither at the top, nor when I scroll down to the last post( #25) is therea Next Page button.
I also looked at some older threads with more than 25 posts and they are the same; no next button.
Les
Peter
Quoting - Les Neilson
Les
Les,
This is interesting. This looks like a problem with IE7.
It seems there is a bug in IE 7 :-). I use both IE and Firefox.
You must have missed my reply to one of your questions if you are using IE 7.
However it appears in IE 8.
Les_Neilson
Quoting - Peter
Les,
Mmm it used to work a couple of weeks ago.
Les
Peter
Les
This is weird now!! :-)
