Tokenize bug?
S-Poulsen
According to the help documentation: "Upon completion of a call to TOKENIZE (set, string, tokens [, separator]), tokens is allocated with a lower bound of one and a size equal to the number of tokens in string, and a character length equal to the length of the longest token in string". However, the following program yields the tokens "my" and "st":
program tokenize_test
    implicit none
    integer :: n
    character(:), dimension(:), allocatable :: tokens
    call tokenize(string="my string", set=" ", tokens=tokens)
    do n=1, size(tokens)
        print '(A, I0, 3A)', "tokens(", n, ") = '", tokens(n), "'"
    end do
end program
Is this a bug, or do I miss something here? If the string is changed to "my string theory", the result is correct. It seems tokenize is using the length of the first token, when the string contains two tokens. I have tested on ifx 2025.2.1 on linux and ifx 2025.1.1 on Windows.
Ron_Green
Looks like a bug.  I will write up a bug report.
Ron_Green
Ron_Green
Bug ID is CMPLRLIBS-35408
Igor_V_Intel
The fix is implemented and will be available in the next major compiler release.
Igor_V_Intel
This bug ix fixed in IFX 2026.0.
