29278 Discussions
in DTIO, v_list size changes when format is built at runtime
jwmwalrus
Hi.
In the following code
module mod1
    implicit none
    public
contains
    function v_list_fmt(v_list) result(fmt)
        character(:), allocatable :: fmt
        integer, intent(in) :: v_list(:)
        integer :: i
        character(20) :: buf
        buf = ''
        print*,'size(v_list)=',size(v_list),new_line('')
        if (size(v_list) == 0) then
            fmt = 'dt'
            return
        endif
        write (buf, '(i0)') v_list(1)
        fmt = trim(buf)
        do i = 2, size(v_list)
            write (buf, '(i0)') v_list(i)
            fmt = fmt//','//trim(buf)
        enddo
        fmt = 'dt('//fmt//')'
    end function
end module mod1
module mod2
    use mod1
    implicit none
    private
    type, public :: child
        integer :: default = -1
    contains
        generic :: write(formatted) => write_child_formatted
        procedure :: write_child_formatted
    end type
    type, public :: parent
        type(child) :: ch
    contains
        generic :: write(formatted) => write_parent_formatted
        procedure :: write_parent_formatted
    end type
contains
    subroutine write_child_formatted(this, unit, iotype, v_list, iostat, iomsg)
        class(child), intent(in) :: this
        integer, intent(in) :: unit
        character(*), intent(in) :: iotype
        integer, intent(out) :: iostat
        character(*), intent(inout) :: iomsg
        if (size(v_list) > 0) then
            write (unit, '("decorated value: ",i0)', IOSTAT = iostat, iomsg = iomsg) 2 ** v_list(1)
        else
            write (unit, '("default value: ",i0)', IOSTAT = iostat, iomsg = iomsg) this%default
        endif
    end subroutine
    subroutine write_parent_formatted(this, unit, iotype, v_list, iostat, iomsg)
        class(parent), intent(in) :: this
        write (unit, '('//v_list_fmt(v_list)//')', IOSTAT = iostat, iomsg = iomsg) this%ch
    end subroutine
end module mod2
use mod2
implicit none
type(parent) :: p
print*,p
end
Because the format is built at runtime, the child receives a non-empty v_list:
$ ifx -V /media/vmshare/v-list-size.f90 && ./a.out
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.4 Build 20241205
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 25.0-1205.1
GNU ld (GNU Binutils for Debian) 2.44
 size(v_list)=           0
decorated value: 1
With other compilers (e.g., gfortran 14.x, flang-new 19.x), I get "default value ..." as output.
So, is ifx doing the wrong thing? Or am I wrong at relying on v_list size?
jwmwalrus
@Ron_Green Any thoughts on this one?
Steve_Lionel
This is clearly, to me, a bug in ifx. write_child_formatted is being called with v_list being a 1-element array, where it should be zero-sized. It doesn't astonish me that this edge case was not considered - it does greatly complicate things with run-time formats. The run-time library has its own format compiler, and it is getting this wrong.
jwmwalrus
Thanks @Steve_Lionel for the reply.
Good to know that, in general, I can rely on v_list size ---but, for now, "one" is the new "zero", hehehe.
Ron_Green
@jwmwalrus I haven't had a chance to look at this in depth.  But since Steve says it's a bug, it's a bug.  I will open a bug report on it and keep you posted on progress.
Ron_Green
I am slow to post the bugID for this one: CMPLRLIBS-35390
