I have a Fortran static library project which is linked to C/C++ program (tried both, pure C and C++). My goal is to execute Fortran code from my C/C++ program and in case there is any error get the traceback information. I am using Visual Studio 2010 with Intel Visual Fortran Studio XE 2013 to build everything.
The problem is that when there is an error in the Fortran code my program crash (which is fine), but I can't get the traceback. However, when I invoke my subroutines from a Fortran program (the main program is a Fortran code), then I get traceback information.
The Fortran static lib is compiled with the following parameters (just the most important): /debug:full /Od /traceback /check:bounds /check:stack /libs:static /threads /dbglibs /c
I found in the documentation that I have to initialize the Fortran runtime library, so that Fortran error handlers are established. I added invocation of for_rtl_init_ in the main() of my C/C++ code, however this doesn't work. The documentation of the for_rtl_init_ subroutine says that it only assigns the Fortran error handlers for Linux and OS X. How can I do that for Windows?
- « Previous
- 1
- 2
- Next »
I'm getting an early error loading the FortranWrapper assembly, and I don't know the managed code environment enough to understand why. All of the projects built successfully, though there's a warning about a dependence on a nonexistent CSCInterfaces reference.
Steve,
I cannot reproduce the error loading the FortranWrapper. What is the excact error message?
The warning about the dependence on nonexistent CSCInterfaces reference could be ignored (caused somehow by copying the project). But in the attached file I have corrected it. Please replace the existing file.
Frank
I figured out the error - it is the one explained here: http://blogs.msdn.com/b/keithmg/archive/2012/03/20/strong-name-validation-failed-exception-from-hresult-0x8013141a.aspx
I undid the delay loading of DLLs used in that project, and also removed the copy of the Intel Fortran libraries being linked against so that the current libraries were used. I can now reproduce the error and will see if I can figure it out. I have a guess....
Steve,
is there any new information available about the "system access violation when calling a FORTRAN subroutine a second or subsequent time".
Thank you!
Frank
Sorry, no. My guess turned out to be incorrect. Still working on it.
- « Previous
- 1
- 2
- Next »
