IR a post dealing with this problem for CVF 6.5 and the poster was referred to Premier Support.
The problem is that reporting to display always works but to a file is iffy.
How did Premier Support resolve this difficulty?
Gerry T.
Gerry T.
Ah, I get it. If the file wasn't CLOSE(d) before TRACEBACKQQ (TB), the results of a successful TB won't be written to the file. Otherwise, the results of successive TBs are appended to the file until a TB aborts the app.
HTH,
Gerry T.
HTH,
Gerry T.
You'll never get referred to Intel Premier Support for a CVF problem - at least not by Intel.
The topic "TRACEBACKQQ not sending output to standard error device)" with CVF 6.5 posted 09-14-2004 and 09-24-2004 ended up being referred by you to Intel Premier Support on 09-24-2004.
Ciao,
Gerry T.
Ciao,
Gerry T.
Ah, that was my error. I did not notice at the time that it was for CVF. Sorry.
