The following test program, when run on a file with fewer lines (2) than the program tries to read (3), gives an incomplete traceback if, in addition to the /traceback option, the /Od option is also specified.
program maj
integer i,j
dimension x(3)
call readfil(x)
end
subroutine readfil(x)
dimension x(*)
open(unit=11,file='inp.txt',status='old')
do i=1,3
read(11,*)x(i)
end do
return
end
The input data file contents (for example) :
10.1 11.2
The traceback from 14.0.4.237, 15.0.0.108 when /Od is not used:
forrtl: severe (24): end-of-file during read, unit 11, file S:\lang\inp.txt Image PC Routine Line Source libifcoremd.dll 00007FF92DB7C352 Unknown Unknown Unknown libifcoremd.dll 00007FF92DBCDD39 Unknown Unknown Unknown tbk.exe 00007FF7DD771151 MAIN__ 5 tbk.f90 tbk.exe 00007FF7DD771F5E Unknown Unknown Unknown tbk.exe 00007FF7DD772307 Unknown Unknown Unknown KERNEL32.DLL 00007FF93CDD16AD Unknown Unknown Unknown ntdll.dll 00007FF93EE434A5 Unknown Unknown Unknown
The traceback when /traceback /Od is used:
forrtl: severe (24): end-of-file during read, unit 11, file S:\lang\inp.txt Image PC Routine Line Source libifcoremd.dll 5EA5C64A Unknown Unknown Unknown tbk.exe 009E10F6 _READFIL 13 tbk.f90 tbk.exe 009E1029 _MAIN__ 5 tbk.f90 tbk.exe 009E1172 Unknown Unknown Unknown tbk.exe 009E2031 Unknown Unknown Unknown KERNEL32.DLL 754D919F Unknown Unknown Unknown ntdll.dll 772CA22B Unknown Unknown Unknown ntdll.dll 772CA201 Unknown Unknown Unknown
If this is the intended behavior, the documentation of /traceback should make it clear that if the user desires a full traceback the /Od option should also be specified.
CORRECTION to #1: please change " the /Od option is also specified." to " the /Od option is not specified also."
Without /Od, the compiler does procedure inlining, so there is not a separate procedure call in the chain.
