29657 Discussions
Tracepoint syntax for printing array
abhimodak
Hi
Does anyone know how to print an array or array section using a tracepoint? If I just put the name of the array, the output window would show {...}. I can see the individual elements by using {a(3)}, {a(7)} etc.
I am wondering if a C++ style FOR loop work; or if one one use VB macro. If VB macro works how to pass the variables and arrays?
Abhi
jimdempseyatthecove
real :: array(1000)
write(*,*) array(100:200) ! section of array
write(*,*) (array(I), I=100,200) ! same section with implied do list
Jim
abhimodak
Hi Jim
Putting array(1:10) or using implied do loop in the print message window of the debugger tracepoint (or when hit of a breakpoint) does not work.
Abhi
jimdempseyatthecove
Quoting abhimodak
Hi Jim
Abhi
Use the Watch window Debug | Windows | Watch (select Watch 1, 2, 3, 4)
enter in the range of the array subscripts. Example:
array(5:10)
On each break point the watch window is updated
Note, you will see
[+] array(5:10)
values not displayed,
Click on [+] to expand array listing, shows [-] followed by expansion
Click again on [-] to collapse array expansion.
Jim
abhimodak
Hi Jim
May be I am not getting this right.. apologies in advance.
I do know how to watch array sections at breakpoint in the watch window. I have been doing that for a long time. What I am wondering is at a "tracepoint" (and not a break-point) I can continue without breaking and print the variables in the "output" window. I can print the scalar variables to the output window using {variable}; I don't know how to do it for arrays.
Abhi
Les_Neilson
Valued Contributor II
From the help it would appear that "tracepoints" were MS targetting C++/C# debugging facility.
Again according to the help:
(a) "You can create a tracepoint from scratch with the New Tracepoint command."
(b) "In a source window, click a line where you want to set a tracepoint and choose Insert Tracepoint from Breakpoints in the shortcut menu."
In VS2008 I cannot findeither of these tracepoint menu options. But it does allow me to convert an existing breakpoint to a tracepoint byclicking onthe breakpoint and selecting "When hit"
Unfortunately the help talks about printing variables (which appears to mean scalars) but doesn't mention arrays.
Howeverit also allows you to run a macro which may be a wayto printarrays. But I don't use macros so can't help you there - sorry.
Les
abhimodak
Hi Les
In VS2005 (and in a Fortran project), I right click the line where I want to insert the breakpoint. Then from the breakpoint dropdown I can select between a breakpoint and a tracepoint. Alternatively, as you mentioned, I use the existing breakpoint and then select "when hit" to get a tracepoint facility.
The print in tracepoint does seem to understand that variable is an array for it prints a {...} when a is an array. I am trying to build a macro but the access to locals has to come through DTE.Debugger.StackFrame.Locals. I haven't fully figured it out yet.
Sincerely
Abhi
