Transfer FORTRAN Dll to other computer for Excel VBA
Chen_W_
Hello All
I made a simple function with Fortran and compiled to Dll for Excel VBA in my computer(Windows 7, 64 bit, excel 2007). It worked well.
but move Dll to another computer(Windows XP, 32 Bit, excel 2007), It cannot work for Excel VBA. the error showing on range: #VALUE!
Please help what the problem come from.
You adivce is very appreciated
Steven_L_Intel1
Most likely you don't have the dependent DLLs on the other computer. For a DLL that is called from EXCEL, the best thing is to relink it to use the static libraries. In your DLL project properties, go to Fortran > Libraries. Change Runtime Library to "Multithreaded" (from "Multithreaded DLL"). Don't select a choice with "Debug" in its name.
Chen_W_
Steve
Thanks a lot, it worked according to your guidance.
Both Multithereaded and Degug Multithereaed can work well. but I don't know what then difference from them
Steven_L_Intel1
Debug Multithread links in the debug version of the Microsoft Visual C++ run-time libraries. These do extra checking on things such as memory allocation. Typically you would not use this when distributing code elsewhere.
