29285 Discussions
Transition from Compaq Fortran to Intel
dytac
I wrote a DLL using Compaq VF that I was able to call from an Excel VBA, and it worked fine (using windows XP, Excel 2003). However, when I transitioned to Vista / Excel 2007, I had to switch to Intel VF; now it doesn't work
I traced the problem to the DLL, which allit does is call a subroutine with a somewhat complex argument list: 1 char string, 2 integers, 1 array of real values, and2 arrays of strings. I had it all wokring previously, so I think that the compiler directives are correct. Below is the actual subroutine, which worked fine with CVF:
SUBROUTINE XLS2MYSUB(ifil,charinput,nlines,ncols,dc_dpou,dc_chou)
! Compiler directives to export DLL
!DEC$ ATTRIBUTES DLLEXPORT,STDCALL :: XLS2MYSUB
!DEC$ATTRIBUTES ALIAS: 'XLS2MYSUB'::XLS2MYSUB
!DEC$ ATTRIBUTES REFERENCE :: ifil,charinput,nlines,ncols,dc_dpou,
& dc_chou
! Parameter Definition
CHARACTER*200 ifil
INTEGER nlines,ncols,i
CHARACTER (LEN=200) charinput(nlines)
CHARACTER (LEN=15) dc_chou(20)
DOUBLE PRECISION dc_dpou(20,2)
! Begin Code
! Set the maximum number of data items per line
ncols = 50
dc_dpou(1,1) = 999.999
! Call MYSUB
!CALL MYSUB_SUB(ifil,charinput,nlines,ncols,dc_dpou,dc_chou)
! Finished
END SUBROUTINE
So this returns the value of 999.999 to the Excel VBA without a problem.The actual call to the subroutine MYSUB_SUB was commented to isolate the problem, if I uncomment it, it stops working. So,I wanted to debug the arguments passed from the excel by writing them outto a file, but it seems I can't do something as simple as openinga file from the DLL, Iusedthe following lines:
open(unit=10,form='formatted',file='C:\temp\junk.dat')
write(10,*) ifil
close(10)
Iknow the above lines work becase I used them sucessfullyback onthe XP side.Is there something fundamentally different in the compiler directives between CFV and IVF? Why does the DLL stop working when I try to open a file? (it works with XP)
David
Les_Neilson
Valued Contributor II
Probably in your Fortran DLL project you need to specify the calling convention as CVF
compiler optiion /iface:cvf or
Project->Properties->Fortran->External Procedures : Calling Convention
Les
dytac
Thanks for the reply, but this didn't work
However, in case you're intereseted I found the problem.
Under "Properties/Fortran/Libraries/ " the "Runtime Library" was set to "Debug Multithread DLL". I had to set it "Debug Multithread", and everything is working now.
