Trapping RTL errors
ereisch
New Contributor II
Any update by chance on the feature request in this post? https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/270668
A quick recap: internal run-time library errors (such as invalid I/O namelist reads, array indexing out-of-bounds, and other "internal" problems) will print a useful stack trace and terminate program execution.  It would be helpful if one could either register a callback which could be executed prior to the exit() call, or raising a signal which could have a user-defined handler registered with the kernel.  This would allow graceful shutdown of things like child-processes or sockets.  I understand the signal-raising method could be difficult since it could leave the RTL in an undefined state if the user tries to do other library-involved operations as part of their handler function.
If the feature hasn't made its way in yet, is there a library-provided function which we can write and link-in an alternative to (with an equivalent prototype) to override the RTL's internal error termination function?
Thanks in advance
Take a look at ESTABLISHQQ.
ereisch
New Contributor II
That appears to be exactly what I needed thanks.  The documentation is a little unclear as to the prototype for the handler function though.  From the example, it appears as though the parameter data types for the handler function are INT, LOGICAL, CHAR(*), and, INT, and it appears as though the size of the last parameter is the word size of the program, but are the first two INT*4 and LOGICAL*4?
They are INTEGER(4) and LOGICAL(4), or default integer and logical. The documentation really ought to include the prototype - I'll ask that that be done. Here's the interface from ifestablish.f90:
    abstract interface
        function establishqq_handler (error_code, continuable, message_string, context)
        import
        ! Function result that indicates whether or not the condition was handled.
        ! .TRUE. means that the handler took action and execution should continue if possible;
        ! .FALSE. means that the handler wishes the RTL to do what it would normally do with this condition.
        logical :: establishqq_handler
        ! Arguments
        integer,      intent(in) :: error_code         ! RTL error code from IOSTAT table
        logical,      intent(in) :: continuable        ! .TRUE. if condition is continuable
        character(*), intent(in) :: message_string     ! Formatted message string as in ERRMSG/IOMSG
        integer(INT_PTR_KIND()), intent(in) :: context ! Address-sized integer as passed in to call to ESTABLISHQQ
                                                       ! For whatever purpose the programmer desires.  The value is
                                                       ! saved, so changes after the establish call have no effect.
        end function establishqq_handler
One thing I see here now (and I have only myself to blame because I wrote this) is that the first two arguments ought to have their kinds explicitly specified using the kinds declared in ISO_FORTRAN_ENV. I'll ask that that be done. Otherwise there could be problems if the program was compiled with different options for integer and logical size.
ereisch
New Contributor II
Ok, thanks.  Last question -- The guide specifies that a C/C++ routine can be used if the ISO_C_BINDINGS module features are used -- does this mean if you use the C bindings to specify the prototype of the handler function, the library will call the C/C++ routine directly, or is this implying a Fortran wrapper needs to be called, and the wrapper can call the C/C++ routine using the bindings module?
That text (which I didn't write!) is incorrect. The module ISO_C_BINDING (no S at the end) has nothing to do with calling procedures. But yes, if you choose to implement the handler routine in some other language, it will be called directly - just make sure that it is interoperable with the interface shown. Note that since one of the arguments is CHARACTER, a hidden length will be passed. (This length is "size_t", passed by value, after all the other arguments.)
ereisch
New Contributor II
It doesn't seem as though the ESTABLISHQQ function can be resolved if you have "-assume nounderscore" specified on your compile line.  If I duplicate the interface found in ifestablish.f90 in my source and append the underscore to the interface, and then manually append the underscore when I call the function, it links successfully.
The better approach is to add to the interface for ESTABLISHQQ:
!DEC$ ATTRIBUTES DEFAULT :: ESTABLISHQQ
I will ask that this be corrected. It's actually a bit worse than this, as the library routine should be called for_establishqq or something like that. Sorry for the problems.
ereisch
New Contributor II
It should be noted that the need for the workaround:
...is still a bug in ifort version 18.0.5.
jimdempseyatthecove
Steve,
Could you suggest to Intel that they a practical example to illustrate its use. An example I would like to see would be a divide by 0 handler where you can insert a desired result. If possible, extend this to a div/0 within a vectorized routine as well.
An example would be in a particle simulation where two particles co-reside.
Jim Dempsey
Steve_Lionel
Jim, that's not possible using ESTABLISHQQ. You could create a routine that does this sort of recovery using the facilities in the IEEE_xxx modules.
