Trying to use the "named block DO construct" as given in the following example in CVF6.6A*:
LOOP_1: DO K = 1, N
A(K) = C * B(K)
END DO LOOP_1
When I make such a statement set in fixed-format (".for" ) source code, I get
"Syntax error, found IDENTIFIER 'DOK' when expecting one of: DO FORALL ..."
I have not specified F77 compatibility, and trust that the fixed-form source code still permits F90 constructs.
Searches of the forum and of the Web have shed no light on my problem.
(*I've obtained 6.6B, 6.6C, and IVF, but have not had the time to go through all the storkdance of qualifying any of them for installation yet. Is there a fix in one of them, perhaps?)
Can anyone point me in the right direction...please Thanks and God bless,
Jack
With the labeled DO, you can't put any of the label in columns 1-6. Start in column 7. Only numeric statement labels can be in columns 1-5, and 6 is for continuation.
Thanks, Steve, for the speedy response.
Tried what you said, and still get the same Error. Here's a direct quote from the source code, the C of Condense being in Col.7. Maybe I've got some bad typography?:
Condense_j: DO j = 1 TO 20 d1 = f1(yada-yada) d2 = f2(yada-yada) f = d1-d2 IF (ABS(f) .LT. tol) THEN EXIT Condense_j ELSE IF (j .EQ. 20) THEN STOP END IF END IF END DO Condense_j !NEXT jand I still get:
: Error: Syntax error, found IDENTIFIER 'DOJ' when expecting one of: DO FORALL SELECT SELECTCASE WHERE IF
Anything else I should be looking out for?
Thanks and God bless!
jack
OOOOPS!
Found it!
Transliterating from Basic is replete with problems, not the least of which is the TOs in the FORs that become DOs needing commas!.
I'm gettin' too old for this, man.
Thanks so much, Steve.
God bless!
Jack
You're welcome. Next time, please post the real source code! It will help get your problem solved sooner.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
