Truncated source line warnings
ereisch
New Contributor II
Revisiting an old topic, would it be possible to add a slightly different option to the "truncated_source" -warn flag that ignores comment fields?  We encourage our developers to heavily comment their code, but with "-warn truncated_source" set, there are a lot of false positives when comments that start with the "!" symbol run past 132 columns.
Thanks for considering.
Steve_Lionel
May I suggest instead that you encourage your developers to use free-form source? You wouldn't have this issue, then. New code should never be developed using fixed-form - it encourages errors.
FortranFan
Nothing to do with free-form source
! Long comment line -----------------------------------------------------------------------------------------------------------------
end
C:\Temp>type p.f90
end
C:\Temp>ifort /c /warn:all /stand p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.085 Pre-Release Beta Build 20190522
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
p.f90(1): warning #5268: Extension to standard: The text exceeds right hand column allowed on the line.
C:\Temp>
Steve_Lionel
That's only if you ask for standards checking - very different from -warn truncated_source (as mentioned in the OP) which applies only to fixed-form.
Of course, even 132 is non-standard for fixed-form.
