29648 Discussions
Trying to compile program with use module on command line
awa5114
I have 2 .f90 files.
file: mod_def.f90
module definedmod
integer :: a = 4
end module definedmod
file: use_mod_def.f90
program usemod
use definedmod
	print *, a
end program usemod
I succeeded in compiling the module definition file using this command:
ifort -c mod_def.f90
THis generated a .obj and .mod file which is good. However when I try to compile the main program
ifort use_mod_def.f90
I get a big error
D:\TEMP\TRUNK-IFORT\test>ifort use_mod_def.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte
l(R) 64, Version 13.0.1.119 Build 20121008
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:use_mod_def.exe
-subsystem:console
use_mod_def.obj
use_mod_def.obj : error LNK2019: unresolved external symbol DEFINEDMOD_mp_A refe
renced in function MAIN__
use_mod_def.exe : fatal error LNK1120: 1 unresolved externals
How do I compile the main program and have it recognize the use module?
As a side notes the online help docs don't  provide a working example. They only gloss over some generalities. It would be good to have working examples that users can copy, paste and work with...
Thanks and look forward to your responses.
awa5114
Nevermind I got it from this thread https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/290070
what I did was:
>ifort use_mod_def.f90 mod_def.obj
Then I got the executable.
