Hi Guys,
i am new and want first of all say hello.
I am working on a project where i have to use the CVF 6.6 for a QuickWIN Application.
I created a Dialog with a Combo Box(IDC_COMBO1) and three Edit boxes (IDC_EDIT_C, IDC_EDIT_CR, IDC_EDIT_MN).
I put the following datas into the Combo Box Data field (enter list box items..): Type A, Type B, Type C.
If i execute the program i can choose between Type A, Type B, Type C, ^so far so good.
The user should be able to choose between Type A, Type B or Type C.
What i want the program to do is:
If the user chooses "Type A",
the Value of EDIT_IDC_C should be 5
the Value of EDIT_IDC_CR should be 6
the Value of EDIT_IDC_MN should be 7
If the user chooses "Type B",
the Value of EDIT_IDC_C should be 8
the Value of EDIT_IDC_CR should be 9
the Value of EDIT_IDC_MN should be 10
If the user chooses "Type C",
the Value of EDIT_IDC_C should be 11
the Value of EDIT_IDC_CR should be 12
the Value of EDIT_IDC_MN should be 13
This is my actual code (of the subroutine of the dialog box):
subroutine Werkstoff( checked )
USE DFLOGM
LOGICAL, INTENT(IN) :: checked
logical ll, l
integer i
type(dialog) WerkstoffDlg
include 'resource.fd'
l = DlgInit( IDD_Werkstoff, WerkstoffDlg )
i = DlgModal( WerkstoffDlg )
call DlgUninit( WerkstoffDlg )
return; call unusedqq( ll )
end subroutine
Is somebody able to help me with this problem?
Marco
USE DFLOGM
logical ll, l
integer i
end subroutine
Marco
Hi Marco,
you have to set a callback routine for your controls, for which you want to have interaction, likeButtons, Checkboxes and Comboboxes.
In your example, it should look like this:
[cpp]subroutine Werkstoff( checked ) USE DFLOGM LOGICAL, INTENT(IN) :: checked logical ll, l integer i type(dialog) WerkstoffDlg include 'resource.fd' l = DlgInit( IDD_Werkstoff, WerkstoffDlg ) l=dlgSetSub(WerkstoffDlg,IDC_COMBO1,onDialogButton) i = DlgModal( WerkstoffDlg ) call DlgUninit( WerkstoffDlg ) return call unusedqq( ll ) end subroutine subroutine onDialogButton (dlg,iButton,iType) implicit none include 'resource.fd' integer(kind=4) iButton,iType character*256 string logical l type (dialog) dlg select case (iButton) case(IDC_COMBO1) l=dlgGet(dlg,IDC_COMBO1,string,DLG_STATE) if(string == 'Type A') then dlgSet(dlg,IDC_EDIT_C,'5') dlgSet(dlg,IDC_EDIT_CR,'6') dlgSet(dlg,IDC_EDIT_MN,'7') ! fill in your other choices...
end if end select return end subroutine onDialogButton [/cpp]
Markus
Quoting - onkelhotte
Hi Marco,
[cpp]select case (iButton)
case(IDC_COMBO1)
end if
end select
return
[/cpp]
That will work, but it's much more elegant to check the selected combo box item position rather than its string:
[cpp]l = DlgGet(Dlg, IDC_COMBO1, iPos, DLG_STATE) !//We'll use the feature that the edit box contents linearly !//depend on the combo position, and use internal write: WRITE(string, "(i2)") 2+3*iPos !//iPos=1 gives 5 l = DlgSet(Dlg, IDC_EDIT_C, string) WRITE(string, "(i2)") 3+3*iPos l = DlgSet(Dlg, IDC_EDIT_CR, string) WRITE(string, "(i2)") 4+3*iPos l = DlgSet(Dlg, IDC_EDIT_CR, string) [/cpp]
Quoting - Jugoslav Dujic
[/cpp]
Hi Jugoslav and Onkelhotte,
thank you both very much for your help, it works!
But for your information, i had to change some things in the code:
- i had to add "use dflogm" to the subroutine "onDialogButton", without this it does not work.
- only "dlgSet(dlg,IDC_EDIT_C,'5')" does not work, you need a "l = dlgSet(dlg,IDC_EDIT_C,'5')"
- instead of (dlg,IDC_EDIT_C,'5') i have to use (dlg,IDC_EDIT_C,"5"C), i dont know why, but otherwise it does not work correctly if i go from TypeA to TypeB to TypeC and back again, the values are not transferred correctly.
Thanks again
Marco
Jugoslav, I use strings because in my programs the entries of a Combo Box are static and so I can easily see which entry was picked. Working with positions would be possible of course, but not intuitive.
@Marco: I forgot the l=, my fault. You have to add the C after your string because it requires a C string, and C strings have a char(0) as the last character.
Markus
