29486 Discussions
Trying to pass 2 or more (1 dimension) array from FORTRAN to VBA (X64)
Aburelo
Hello , i was trying to pass 2 arrays from fortran to vba ,i get passing 1 or 2  arrays , but when i try to pass 3 or more , Excel Crashes .
FOR 1 ARRAY 1 Dimension i didnt have problems
this is the code:
:::::::::::::::::::::::::::::::::::::::::::::::::::::: 1 ARRAY 1 DIMENSION ::::::::::::::::::::::::::::::::::::::::::::::::::::::::
FORTRAN SIDE:
      SUBROUTINE INOUTA (FIV)
	!DEC$ ATTRIBUTES DLLEXPORT,stdcall,reference,ALIAS:'INOUTA' :: INOUTA
      Real, Dimension(20,1) :: FIV
      DO 1 I=1,20
      FIV(I,1)=I*2
   1  CONTINUE
      RETURN
      END
VBA SIDE:
Public Declare PtrSafe Sub ABSUB Lib "ABSINOUT.dll" Alias "INOUTA" (outarray As Single)
Public Function FABS() As Variant
ABSactualWorkpath = ThisWorkbook.Path
ChDir ABSactualWorkpath
Dim ALEX(1 To 20, 1 To 1) As Single
Call ABSUB(ALEX(1, 1))
FABS = ALEX
End Function
:::::::::::::::::::::::::::::::::::::::::::: 2 ARRAYS 1 DIMENSION ::::::::::::::::::::::::::::::::::::::::::::::::::::
Fortran side:
      SUBROUTINE INOUTA (FIV,POX)
	!DEC$ ATTRIBUTES DLLEXPORT,reference,stdcall,ALIAS:'INOUTA' :: INOUTA
      Real, Dimension(20,1),intent(INOUT) :: FIV,POX
      DO 1 I=1,20
      FIV(I,1)=I*1
   1  CONTINUE
      DO 2 I=1,20
      POX(I,1)=I*2
   2  CONTINUE
      RETURN
      END SUBROUTINE INOUTA
vba side:
Public Declare PtrSafe Sub ABSUB Lib "ABSINOUT.dll" Alias "INOUTA" (ByRef outarray As Single, ByRef outarry As Single)
Dim ALEXX(1 To 20, 1 To 1) As Single
Call ABSUB(ALEX(1, 1), ALEXX(1, 1))
FABS = ALEX
End Function
but whwn i try to pass 3 arrays excel crashes:
this is the code i wrote for 3 arrays
::::::::::::::::::::::::::::::::::::::::::::: 3 ARRAYS 1 DIMENSION ::::::::::::::::::::::::::::::::::::::::::::::::::::
Fortran:
      SUBROUTINE INOUTA (FIV,POX,TETP)
      Real, Dimension(20,1),intent(INOUT) :: FIV,POX,TETP
      DO 1 I=1,20
      FIV(I,1)=I*1
   1  CONTINUE
      DO 2 I=1,20
      POX(I,1)=I*2
   2  CONTINUE
      DO 3 I=1,20
      TETP(I,1)=I*3
   3  CONTINUE
      RETURN
VBA SIDE:
Public Declare PtrSafe Sub ABSUB Lib "ABSINOUT.dll" Alias "INOUTA" (ByRef outarray As Single, ByRef outarry As Single, ByRef outay As Single)
Dim ALEXXX(1 To 20, 1 To 1) As Single
Call ABSUB(ALEX(1, 1), ALEXX(1, 1), ALEXXX(1, 1))
FABS = ALEX
End Function
did you know why is this happening?  i annex both examples , you need to use 64 bits excel to run it.
Aburelo
UPDATE#6 ... i find no matters if you activate  the references , just activate one of them , and this repair the file.... i dont know why but i think its only refreshing the references
Aburelo
UPDATE1: I open my file in another computer, and i was able to get 2 arrays, , i think the problem is related to the excel version or computer settings...
UPDATE2:  i update my EXCEL 365 to the version 2207 Build 16.0.15427.20182 64-bits  and it helps for the  2 arrays error but i still not able to run 3 or more....:/
Aburelo
UPDATE#3: I ADDED THIS REFERENCES IN VBA EXCEL REFERENCES TABLE...suprisely the code now work for 3 arrays!, going to try for 5 arrays to see if that helps!
I ANNEX THE REFERENCES CODES  (i added these files in this reply), added to your reference code in visual basic in excel and select the VFPROj.dll and acept it magically it start working!  , Also i copy the file to my another computer and works too =,D!
Aburelo
UPDATE #4  , trying to pass 4 arrays breaks excels again......the solution was dissabling the "Intel Fortran project Extensibility 13.0 type library" and then its start working for 4 arrays......
also i activate the Intel Fortran project Extensibility 18.0 type library and excel keep working well...
Aburelo
UPDATE#5  I try with 6 arrays and stop working... i desactivate the  Intel Fortran project Extensibility 18.0 type library and then ...solved...weird but now it can hanndle 6 arrays without problem
Aburelo
AlHill
Let us know when you get to 128 arrays.
Aburelo
Sorry i was trying to be detailed because this cost me lot of time , i hope someday one person have the same problem and this post help him. I notice for 3 or more arrays you need to able that reference, but after that you need to Refresh your refereces. that only that.
