Two strange Warnings(6706;6738) with abstract interfaces
Wolf_W_
Hello, i get those two warning messages, when compiling the code below.
"(22) warning #6706: There is a mixture of specific functions and specific subroutines for one generic-spec.   [INTF_SETARRAY]"
"(28) warning #6738: The type/rank/keyword signature for this specific procedure matches another specific procedure that shares the same generic-name.   [INTF_GETSCALAR]"
I do not understand, what is wrong with those declarations. This contruct seems to work fine in my real code, but the warnings confused me.
Greetings
Wolf
Compiler: 15.5 and 16.1
module FOO
  implicit none
  type, abstract :: ABSTRACT_TYPE
  contains
    procedure(intf_getArray),  deferred :: getArray
    procedure(intf_setArray),  deferred :: setArray
    procedure(intf_getScalar), deferred :: getScalar
    procedure(intf_setScalar), deferred :: setScalar
  end type ABSTRACT_TYPE
  interface abstract
    real pure function intf_getArray(this) result(res)
      import :: ABSTRACT_TYPE
      class(ABSTRACT_TYPE), intent(in   ) :: this
    end function
    pure subroutine intf_setArray(this, inp)
      class(ABSTRACT_TYPE), intent(inout) :: this
      real,                 intent(in   ) :: inp(3)
    end subroutine
    real elemental function intf_getScalar(this) result(laenge)
    end function
    elemental subroutine intf_setScalar(this, inp)
    end subroutine
  end interface
  type, extends (ABSTRACT_TYPE) :: EXTENDED_TYPE
  contains
    procedure :: getArray     => getArray_Extended
    procedure :: getScalar    => getScalar_Extended
    procedure :: setArray     => setArray_Extended
    procedure :: setScalar    => setScalar_Extended
  end type EXTENDED_TYPE
contains
  pure function getArray_Extended(this) result(res)
    class(EXTENDED_TYPE), intent(in   ) :: this
    real                                :: res
  end function
  real elemental function getScalar_Extended(this)
  end function
  pure subroutine setArray_Extended(this, inp)
    class(EXTENDED_TYPE), intent(inout) :: this
  end subroutine
  elemental subroutine setScalar_Extended(this, inp)
  end subroutine setScalar_Extended
end module FOO
FortranFan
There appears to be a couple of issues here:
  1. I assume you meant "abstract interface" on line 16 instead of "interface abstract".  I would think the line "interface abstract" would signal to the compiler an attempt to provide a generic interface named abstract and in which case the compiler should give an error (not a warning) that all the procedures in said generic need either be all SUBROUTINE or FUNCTION procedures.  This would appear to be a bug in the compiler that it does not give such an error.
  2. If you change your code to "abstract interface", then the code compiles ok but gives "warning #6178: The return value of this FUNCTION has not been defined.   [GETSCALAR_EXTENDED]" which also seems spurious, similar to the other thread you created around the same time as this one.
FortranFan
Wolf_W_
Well, this was obviously my fault. As you said, changing line 16 to "abstract interface", resolves the issue. The warning #6178 seems right to me, as there is no result value given in the function, because i stripped everything unimportant.
Thank you very much FortranFan!
FortranFan
Wolf W. wrote:
.. The warning #6178 seems right to me, as there is no result value given in the function..
I could be wrong but the warning #6178 seems to indicate the compiler doesn't notice the code says "real elemental function getScalar_Extended.."
Lorri_M_Intel
"The return value of this FUNCTION has not been defined" means that nothing has been assigned to the return value of the function.
             --Lorri
FortranFan
             --Lorri
Ok, but then shouldn't the compiler issue the same warning about getArray_Extended function?
Lorri_M_Intel
:-)  Yes.
