Type bound generic operator oddity
IanH
With 12.0.4 (and earlier) I'm getting some unexpected errors about user-defined type-bound operators.
[fortran]MODULE GenericUnaryOperatorModule
   IMPLICIT NONE
   TYPE, ABSTRACT :: Parent
     CHARACTER(:), ALLOCATABLE :: some_text
   CONTAINS
     PROCEDURE(parent_UnaryOp_abstract), DEFERRED :: UnaryOp
     GENERIC :: OPERATOR(.UnaryOp.) => UnaryOp
   END TYPE Parent
   ABSTRACT INTERFACE
     FUNCTION parent_UnaryOp_abstract(lhs) RESULT(res)
       IMPORT Parent
       IMPLICIT NONE
       CLASS(Parent), INTENT(IN) :: lhs
       CLASS(Parent), ALLOCATABLE :: res
     END FUNCTION parent_UnaryOp_abstract
   END INTERFACE
   TYPE, EXTENDS(Parent) :: Extension
   CONTAINS
     PROCEDURE :: UnaryOp => ext_UnaryOp
   END TYPE Extension
CONTAINS
   FUNCTION ext_UnaryOp(lhs) RESULT(res)
     CLASS(Extension), INTENT(IN) :: lhs
     CLASS(Parent), ALLOCATABLE:: res
     ALLOCATE(res, SOURCE=Extension('ext_UnaryOp'))
   END FUNCTION ext_UnaryOp
   SUBROUTINE dump(arg)
     CLASS(Parent), INTENT(IN) :: arg
     PRINT "(A)", arg%some_text
   END SUBROUTINE dump
END MODULE GenericUnaryOperatorModule
PROGRAM GenericUnaryOperator
   USE GenericUnaryOperatorModule
   IMPLICIT NONE
   CLASS(Parent), ALLOCATABLE :: a
   TYPE(Extension) :: b
   ALLOCATE(Extension:: a)
   CALL dump(.UnaryOp. a)
   ! Unexpected error #6764?
   CALL dump(.UnaryOp. b)     ! #1
END PROGRAM GenericUnaryOperator
[/fortran]
If you comment out #1 above to allow compilation to succeed you'll get a link time reference to the abstract interface (I think that's already reported?).
This is a follow on from a post on c.l.f recently (http://coding.derkeiler.com/Archive/Fortran/comp.lang.fortran/2011-05/msg00504.html) where I was blundering around trying to understand how these generics could be used. The code in that post shows some very wishful but erroneous thinking on my part and also the compiler failing to pick up on ambiguous interfaces for the generic.
Thanks - I have escalated this issue as DPD200169597.
A fix for this has been found and will be in a release later this year. Sorry for the delay.
