29383 Discussions
Type bound generics and dotted strings
IanH
The following gives acompletly whackedspurious error message that indicates that "operator resolution" for a a user defined operator applied to a component of a derived type is being carried out based on the name of a dummy argument ... in a different procedure .... in a different module.
[fortran]
MODULE A
  IMPLICIT NONE
  PRIVATE
  TYPE, PUBLIC :: TypeA
  CONTAINS
    PROCEDURE :: is_op
    GENERIC :: OPERATOR(.is.) => is_op
  END TYPE TypeA
CONTAINS
  PURE FUNCTION is_op(str, idx) RESULT(mvconc)
    CLASS(TypeA), INTENT(IN) :: str
    INTEGER, INTENT(IN) :: idx
    REAL :: mvconc
    mvconc = 0.0
  END FUNCTION is_op
END MODULE A
MODULE B
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: irrelevant_proc
  TYPE, PUBLIC :: TypeB
  END TYPE TypeB
CONTAINS
  ! Note dummy argument name.
  SUBROUTINE irrelevant_proc(My)
    TYPE(TypeB), INTENT(IN) :: My
  END SUBROUTINE irrelevant_proc
END MODULE B
MODULE C
  USE A
  IMPLICIT NONE
  PRIVATE
  INTEGER, PARAMETER, PUBLIC :: rising =  1
  TYPE, PUBLIC :: TypeC
    TYPE(TypeA) :: exasperation
  END TYPE TypeC
CONTAINS
  SUBROUTINE proc(My)
    TYPE(TypeC), INTENT(INOUT) :: My
    PRINT *, My % exasperation .is. rising
  END SUBROUTINE proc
  SUBROUTINE another_proc
    USE B, ONLY: irrelevant_proc
  END SUBROUTINE another_proc
END MODULE C
[/fortran]
[plain]
>ifort /c /check:all /warn:all /standard-semantics DottedStringWTF.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 13.0.0.089 Build 20120731
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
DottedStringWTF.f90(11): remark #7712: This variable has not been used.   [STR]
DottedStringWTF.f90(11): remark #7712: This variable has not been used.   [IDX]
DottedStringWTF.f90(28): remark #7712: This variable has not been used.   [MY]
DottedStringWTF.f90(45): error #6866: Dotted string neither a defined operator nor a structure component   [IS]
DottedStringWTF.f90(43): remark #7712: This variable has not been used.   [MY]
  SUBROUTINE proc(My)
compilation aborted for DottedStringWTF.f90 (code 1)
[/plain]
Anonymous66
Valued Contributor I
Hello Ian, I have escalated this issue to the developers the issue number is DPD200237125. I will post any updates I receive to this thread. Regards, Annalee Intel Developer Support
Anonymous66
Hello Ian,
A fix has been found for this issue. We are currently planning to include it the next major release which is scheduled for later this year.
Regards, Annalee
Ron_Green
This bug was fixed in the recent Composer XE 2013 SP1 release, released in early September ( version 14.0 of the compiler )
ron
