Type mismatch
Alessandro
I have a program that can work in single or double precision, depending on the value of the variable kvar which may be sgl or dbl (4 or 8). I have some routines that accept only a specific kind though, and I tried the following:
complex(kind=kvar) G_fft
if (kvar.eq.dbl) then
! do nothing
elseif (kvar.eq.sgl) then
call transfer_c(G_fft,dv_Gfft,.true.)
endif
When I try to compile it with kvar set to dbl it gives me the following error:
Error 1 error #6633: The type of the actual argument differs from the type of the dummy argument. [G_FFT] E:\Codice\IterSolver_v14x1\MGM.F90 902
Is there anything I can do?
Alessandro
Andrew_Smith
Valued Contributor I
Quoting - Alessandro
! do nothing
endif
Error 1 error #6633: The type of the actual argument differs from the type of the dummy argument. [G_FFT] E:CodiceIterSolver_v14x1MGM.F90 902
Alessandro
I dont know what transfer_c does but if it similar to the Fortran transfer function then it would not be suitable. Why not try: dv_Gfft = G_fft
Alessandro
Quoting - Andrew Smith
It's a wrapper for CUDA, dv_Gfft is more like a struct, and transfer_c deals with the transfer of the data into the variable of the device.
TimP
Then it seems you should make your own function to copy from your version of the struct with non-compliant types to the one required by CUDA. If you were using C, you could depend on prototypes to make implicit conversions of simple variables, but not for a struct.
tom_p
If I understand you correctly, the code compiles if kvar ist set to sgl. As the value of kvar has to be known at compile time anyway, the simplest solution seems to be to use conditional compilation:
#ifdef SGLPREC
#endif
You could define your parameter kvar like this:
#ifdef SGLPREC
integer, parameter :: kvar = sgl
#else
integer, parameter :: kvar = dbl
#endif
To compile the program with single precision:
ifort -fpp -DSGLPREC [...]
and with double precision:
ifort -fpp [...]
