29231 Discussions
Type parameter inquire (F2018: 9.4.5)
Harald1
New Contributor II
ifort/ifx-21.3 do not accept type parameter inquiries as described in F2018 section 9.4.5.
Example:
character(len=5)   :: str
integer, parameter :: n = len (str)      ! accepted (ok)
integer, parameter :: i = kind(str)      ! accepted (ok)
integer, parameter :: j = str% kind      ! not accepted
integer, parameter :: k = str% len       ! not accepted
integer, parameter :: l = str(1:3)% len  ! not accepted
integer, parameter :: m = str(1:3)% kind ! not accepted
end
 I get:
%ifort ifort-inquiry.f90
ifort-inquiry.f90(4): error #7169: Bad initialization expression.   [STR]
ifort-inquiry.f90(5): error #7169: Bad initialization expression.   [STR]
ifort-inquiry.f90(6): error #7169: Bad initialization expression.
ifort-inquiry.f90(7): error #7169: Bad initialization expression.
compilation aborted for ifort-inquiry.f90 (code 1)
 Expected: no output (everything is accepted).
Note: lines 4 and 5 are accepted e.g. by gfortran 9+, but (not yet) lines 6 and 7.
Harald
Mark_Lewy
Valued Contributor I
Interesting, so I wondered what would happen if you used variables instead of parameters:
program type_params
    implicit none
    character(5) :: str
    integer :: o, p, q, r, s, t
    print *, 'Hello World'
    o = len (str)
    p = kind(str)
    q = str% kind
    r = str% len
    s = str(1:3)% len
    t = str(1:3)% kind
    print*, o, p, q, r, s, t
end program type_params
This is the output I get:
Hello World
5 1 1 5 -1525680944 1
It looks like using the len inquiry on a substring is not working as expected either.
ifort 2021.3 x64
andrew_4619
The parameter case on line 4 and 5 should be good as it is a "constant expression" I am not sure about the sub-string case. Hopefully someone from Intel will pick up this bug.
FortranFan
At first glance, the code in the original post looks conforming.  Hopefully Intel staff can pick it from here.
IFORT response to line 4 (and may be 7) is surprising especially because a similar situation with parameterized derived types (PDTs) I had reported was resolved by Intel sometime back.  A processor can superficially treat the CHARACTER intrinsic type as if a "pseudo" PDT with one kind-type parameter labeled KIND and one length-type parameter named LEN and thus support some of these syntactic sugar introduced starting Fortran 2003.
Barbara_P_Intel
Thank you, gentlemen, for all this information. I filed a bug report, CMPLRIL0-34090, on these issues with type parameter inquire. I'll let you know its progress to a fix.
