USE module - Compilation error
mtl
Dear everyone,
I programmed a module, ReadMe, to read the input data from txt files and save it in an array, qrrf. The input data is variable-size arrays for each time step. The errors and main code are shown below. Would you please me some advice on this problem? Thank you in advance for your time and help.
When I compile the code, it shows several errors as below:
Error Compilation Aborted (code 1) D:\...\ppane .for 1
Error error #6406: Conflicting attributes or multiple declaration of name. [READH1DIN] D:\...\ppane .for 719
Error error #6580: Name in only-list does not exist or is not accessible. [READH1DIN] D:\...\ppane .for 109
Error error #7002: Error in opening the compiled module file. Check INCLUDE paths. [ReadMe]
  • Line 109:   USE ReadMe, ONLY: ReadH1DIN
  • Line 719:   qrrf = ReadH1DIN ('qrrf_dt', Nk)
The main code is shown below:
(1) subroutine
subroutine ppane (t, z, nd, sat)
   DOUBLE PRECISION, ALLOCATABLE, SAVE ::  qrrf(:,:)
END Subroutine
(2) function
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC  Start
C     FUNCTION         ReadH1DIN
      MODULE ReadMe
      CONTAINS
      FUNCTION ReadH1DIN (NAMEIN,Nk)
      IMPLICIT DOUBLE PRECISION (A-H, O-Z)
      INTEGER InputH1D, IIND, Nk
      CHARACTER(LEN=75) :: FILNAM
      CHARACTER NAMEIN*(*)
      DOUBLE PRECISION, ALLOCATABLE :: ReadH1DIN(:,:)
      WRITE (FILNAM,1225) NAMEIN,'.txt'   !Define the path and name of the input data text file
 1225 FORMAT (A,A4)
      OPEN (UNIT=101, FILE=FILNAM, STATUS='OLD')
      READ(101,*) !Skip the header
      InputH1D = 0
      DO
          READ(101,*,IOSTAT=IO) TRASH
          IF (IO.NE.0) EXIT !Exit the loop when last line has been reached
          InputH1D = InputH1D + 1 !Counts how many time periods inputs are set for the input data type
      END DO
      REWIND(101)  !Rewind text file to read the inputs
      ALLOCATE(ReadH1DIN(InputH1D,2*Nk))  !Allocate the input data array
      DO 1226 IH1D=1,InputH1D
          READ(101,*) (ReadH1DIN(IH1D,IIND), IIND=1, 2*Nk) !Save the data in the main array
 1226 CONTINUE
      RETURN
      END FUNCTION
      END MODULE ReadMe
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC  End
JohnNichols
Honored Contributor I
There is a icon you press that allows you to insert the code in Fortran format.  I suggest you repost the code so it is easier to read.  Provide a sample input and then it can be run.
mtl
I have followed your suggestion and add the whole “Module” code. Would you please go through it at your convenience?
Thank you very much for your time.
Steve_Lionel
There is, I am certain, code you have not shown us that is relevant to this problem.
Why are you writing fixed-form source in 2022?
mtl
Thank you very much.
I add the whole “Module” code. Would you please go through it at your convenience?
Thank you for your time and help.
Steve_Lionel
You still have not shown us enough. The source you did show compiles without error.
Please attach a ZIP of a minimal reproducible example.
mecej4
I removed the lines of code with "..." from what you posted, compiled the module source file and then the subroutine source file (you call this the "main code", but this is not the main program unless you are building a DLL). The compilation did not produce any warning or error messages; therefore, any errors that you encountered are attributable to lines of code that you did not show us yet. The subroutine code that you showed contains only five lines, whereas one of the error messages refers to line 719 and the other to 109.
jimdempseyatthecove
Taking a flying leap ...
Perhaps have you made a module out of some old code?
If so, check to see if you forgot to remove:
    EXTERNAL ReadH1DIN
From the code than now contains
Jim Dempsey
