29273 Discussions
Does Intel Fortran compiler support -fsanitize=address like the one for C++?
Carlygao
I need to detect the memory leakage location or any stack corruption. Does Intel Fortran compiler support -fsanitize=address, or provide any feature to help me to identify the error location? Thanks.
Carly
Steve_Lionel
Intel Inspector, a tool that is part of the oneAPI HPC Toolkit, can detect memory leaks. There is /check:stack that can identify some kinds of stack corruption.
Carlygao
Hi Steve,
I installed oneAPI HPC Toolkit. Can you give me more details about how to  set up /check:stack? I am using Visual Studio 2019. Thanks.
Carly
Steve_Lionel
The best thing to do is build a Debug configuration. This not only enables /check:stack (Fortran > RunTime > Check Stack Frame > Yes, ifort only) but also links in the debug version of the MSVC library that initializes all allocated memory to hex CCCCCCCC and provides some other run-time checks. This may not help for errant writes to otherwise valid stack locations, however.
The way I usually work such issues is to gradually cut out parts of the program - starting with stuff after the error - to find what minimal change results in a different behavior. You might also experiment with compiling some sources with optimization and some without, to see which source affects the issue. (Use binary search to narrow this down.)
Carlygao
After I turned on al the options mentioned here, I got some more error information. The code immediately crashed in the beginning and triggered the "ntdll.pdb not loaded" page. In the out windows, it complains "'bsam20_2022_09_30_9b502dd.exe' (Win32): Loaded 'C:\Windows\System32\imm32.dll'.
HEAP[bsam20_2022_09_30_9b502dd.exe]: Invalid address specified to RtlValidateHeap( 00000156837E0000, 0000118283DA3380 )
bsam20_2022_09_30_9b502dd.exe has triggered a breakpoint."
Does this mean I have stack corruptions? How should I do next to detect the bug?
BTW, I am using a very big code package mixing Fortran and C++. Thanks.
Carly
Steve_Lionel
Those DLL messages are not errors or complaints - they're just informational from the debugger telling you which DLLs have debug info and which don't. You should ignore this. Same with the ntdll.pdb message.
You have some sort of corruption - it could be stack or heap (dynamic allocation). What I find interesting in the call stack is that it all seems to go wrong at the program start, perhaps before any of your code executes. I don't see any Fortran frames in there. What happens if you set a breakpoint on the first executable line in the program? If it gets there OK, how far into the code does it get before the error occurs?
If this were a 32-bit application I might be concerned with STDCALL vs. C calling conventions, but I see it is 64-bit where that doesn't apply.
Do you have a DLL initialization function (DllMain) anywhere in your sources?
