USEROPEN specifier
Chris_G_2
I am experimenting with the USEROPEN specifier in OPEN statements to bypass the Fortran RTL. I started with the example in the Intel documentation in the section 'OPEN: USEROPEN Specifier'. I have been trying the example for Windows systems, but it gives a Program Exception - access violation on line 108.
Has anyone else had this problem or could offer a fix?
I enclose the relevant folder.
andrew_4619
Did you try null terminating the file name string that is passed?
Chris_G_2
Thanks, Andrew.
I have found a second, different example in the documentation and this works fine (without the need for null termination of the string, so I am using that at the moment.
andrew_4619
Glad you fixed it. If there is a duff example in the latest documents file a ticket on it then at least it will get fixed....
Chris_G_2
Actually the documentation is OK - it's  just my stupidity.
