Ubuntu 15.04 (64) not supported by Intel parallel studio XE 2016 update 2 for linux
Akhi_N_
I am interested in installing trial version of Intel fortran and C compiler. But while installing using the CLI as well as GUI the programs fails at Prerequisites. For Ubuntu 15.04 which version should I use?
Akhi
TimP
If it's simply a question of your Ubuntu being newer than the ones available for testing at the time the ifort release was prepared, try accepting the unsupported installation. If it's failing 32-bit mode installation on account of you not having a full 32-bit g++ installation, don't install for ia32 mode.  You will need the 64-bit Ubuntu g++ development mode installation.   If it's more than this, check which prerequisites are missing and show us.
Steven_L_Intel1
Ubuntu 15.04 is supported by the version of Intel Parallel Studio XE you installed. Please provide the information Tim asks for - show us the error messages during installation.
Akhi_N_
Thank you Tim P. Sir And Steve Sir for your prompt reply,
I Could Install the compiler package successfully ignoring the optional prerequisites. But even after initialization using "psxevars.sh " I get ifort command not found error.
Akhi_N_
TimP
If you are running tcsh or csh, the command for 64-bit compiler setup would be
source compilervars.csh intel64
The '.' in the docs is the bash abbreviation for 'source'
Akhi_N_
Thank you Sir, I could successfully install the compilers.
