29350 Discussions
Ubuntu 15.04 (64) not supported by Intel parallel studio XE 2016 update 2 for linux
Akhi_N_
I am interested in installing trial version of Intel fortran and C compiler. But while installing using the CLI as well as GUI the programs fails at Prerequisites. For Ubuntu 15.04 which version should I use?
Akhi
TimP
If it's simply a question of your Ubuntu being newer than the ones available for testing at the time the ifort release was prepared, try accepting the unsupported installation. If it's failing 32-bit mode installation on account of you not having a full 32-bit g++ installation, don't install for ia32 mode.  You will need the 64-bit Ubuntu g++ development mode installation.   If it's more than this, check which prerequisites are missing and show us.
Ubuntu 15.04 is supported by the version of Intel Parallel Studio XE you installed. Please provide the information Tim asks for - show us the error messages during installation.
Akhi_N_
Thank you Tim P. Sir And Steve Sir for your prompt reply,
I Could Install the compiler package successfully ignoring the optional prerequisites. But even after initialization using "psxevars.sh " I get ifort command not found error.
Akhi_N_
TimP
If you are running tcsh or csh, the command for 64-bit compiler setup would be
source compilervars.csh intel64
The '.' in the docs is the bash abbreviation for 'source'
Akhi_N_
Thank you Sir, I could successfully install the compilers.
