29284 Discussions
Ubuntu 18.04.3 may break compilers ifort: error #10105: ld: core dumped
Ron_Green
Ubuntu's latest build of 18.04 LTS is 18.04.4
Their previous build, 18.04.3, had an issue that may affect (break) the Intel compilers.
Earlier builds like 18.04.2 and 18.04.1 are compatible and work with the Intel compilers.
You can find your Ubuntu build number by:
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.4 LTS"
Notice DISTRIB_DESCRIPTION.  On this system it is the latest 18.04.4 LTS.
If your DISTRIB_DESCRIPTION has "18.04.3" you may have issues running the Intel compilers due to an issue with glibc in this specific build.
The error will be
ifort hello.f90
ifort: warning #10102: unknown signal(-320620368)
ifort: error #10106: Fatal error in ld, terminated by unknown
Upgrading your Ubuntu to the latest 18.04.4 will install a fixed glibc along with other important updates to Ubuntu.
sudo apt-get update
sudo apt update
mgpinedocuba
I have this version of Ubuntu:
DISTRIB_ID=Ubuntu
DISTRIB_DESCRIPTION="Ubuntu 18.04.5 LTS"
and the error still appears
ifort: warning #10102: unknown signal(-1797457744)
What I can do?
Ron_Green
check your libc and binutils versions
Here's what I see on my 18.04.5 system
apt list --installed | grep libc
libc6/bionic-updates,now 2.27-3ubuntu1.4 amd64 [installed]
ld --version
GNU ld (GNU Binutils for Ubuntu) 2.30
apt list installed | grep binutils
binutils/bionic-updates,now 2.30-21ubuntu1~18.04.4 amd64 [installed]
binutils-common/bionic-updates,now 2.30-21ubuntu1~18.04.4 amd64 [installed]
binutils-x86-64-linux-gnu/bionic-updates,now 2.30-21ubuntu1~18.04.4 amd64 [installed]
libbinutils/bionic-updates,now 2.30-21ubuntu1~18.04.4 amd64 [installed]
mgpinedocuba
hi, when i put the command:
appears the next message:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
It seems strange to me, before the ubutu updates, I could use the ifor in a normal way, but after updating ubuntu these errors started.
