Hi everybody,
as stated in the Title I'm trying to install l_fcompxe_2011.10.319 package on my new 64-bit notebook, which is now running Ubuntu 12.04 OS. Before attempt the installation, I run these commands:
apt-get install build-essential
apt-get install gcc-multilib
apt-get install rpm
apt-get install openjdk-6-jre-headless
according to http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu/
Everything is ok until step 4, where I get this message:
Step no: 4 of 6 | Options > Missing Optional Pre-requisite
32-bit libraries not found on this system.
This product release requires the presence of 32-bit compatibility libraries
when running on Intel 64 architecture systems. One or more of these libraries
could not be found:
libstdc++ (including libstdc++6)
glibc
libgcc
Without these libraries, the compiler will not function properly. Please refer
to Release Notes for more information.
I'm not new of Ubuntu but still not expert... do I still need version 5 of libstdc++? can someone please help me someway?
lots of thanks
Riccardo
apt-get install rpm
could not be found:
glibc
libgcc
lots of thanks
Riccardo
Riccardo,
It's the ia32-libs package that needs to be installed on Ubuntu 64-bit ($ sudo apt-get install ia32-libs) when you want to use the 32-bit compiler. If not, you can ignore this message.
Hubert.
Hubert.
I am not familiar with Ubuntu, but in essence what you need before a successful installation of Intel Fortran is the capability to build and run C/C++ programs from source code. The specific package(s) that give you that capability depend on the "distro"; it is often called GCC 32-bit compatibility package or something similar.
Riccardo,
Hubert.
Hubert.
Mecej4 and Hubert,
thank you very much for your help and attention, I'll then proceed with installation.
ciao
R
ciao
R
Hubert,
installation have been completed successfully, but when I invoke "ifort mycode.f" in the terminal it gives me:
fortcom: File o directory non esistente
ifort: error #10273: Fatal error in fortcom, terminated by 0x64
I tried:
/(my installation path)/Intel/bin/ifort mycode.f
and it works. I tried to fix the problem using:
13- nano .bashrc
the nano editor will open ".bashrc" file,
go to the end of this file and add the following lines:
PATH="/opt/intel/Compiler/11.0/081/bin/intel64:$PATH"
export PATH
LD_LIBRARY_PATH="/opt/intel/Compiler/11.0/081/lib/intel64:$LD_LIBRARY_PATH"
export LD_LIBRARY_PATH
from http://ubuntuforums.org/showthread.php?t=1082782&highlight=ifort, but it didn't work. Note that instead of /opt/intel/Compiler/11.0/081/bin/intel64 I wrote:
/(my installation path)/Intel/composer_xe_2011_sp1.10.319/compiler/lib/intel64
The compiler seems to work, now it's just a matter of convenience: every time I need the ifort command I have to type its entire path...
thank you again
Riccardo
I tried:
13- nano .bashrc
export PATH
thank you again
Riccardo
Riccardo,
Doesn't look like that you invoked the compiler source script, default:
$ source /opt/intel/bin/compilervars.sh intel64
Hubert.
Hubert,
this is what I have in my /opt/intel directory:
gaucho@koala:/opt/intel$ ls
ActivationTool intel_sdp_products.db licenses
I did not install the compiler in the default path because of limited hard disk space in the system partition. It's in the home directory:
/home/gaucho/Programmi/intel/...
Riccardo
Riccardo
If you want the compilervars script sourced automatically, you can add that to the startup script for opening windows under the shell you use. This is mentioned in the docs.
maybe you can put this in your .bashrc , it will did like what Hubert mean
source /home/gaucho/Programmi/intel/bin/compilervars.sh intel64
Hello, guys.
I'm having the same problem. I'm trying to install Intel Fortran Composer XE 2011 on 64bit Ubuntu LTS 12.04 and the installer is complaining about missing 32bit pre-requisites:
could not be found:
glibc
libgcc
Riccardo, how did you bypass this step in the installation?
Hubert, I did apt-get install ia32-libs but it didn't help. I'm still getting the same message.
I started the installation with running:
apt-get install rpm
Can you please advise.
Thank you.
Vakho
could not be found:
glibc
libgcc
apt-get install rpm
Thank you.
Vakho
Vakho,
There is another option: don't install the 32bit compiler and just install the 64bit compiler.
The IRC has 4 packages you can download. If you choose the "Product for 32-bit/64-bit (x64) development" that kit will install the 32bit compiler and requires a full 32bit gcc and libraries to be installed on your system.
Many distros are not shipping the 32bit dev tools by default.
IF you only want or care about 64bit development, go to https://registrationcenter.intel.com and download the kit "Product for 64bit (x64) development" and install it. It does NOT require the 32bit dev environment.
ron
ron
