Ugly situation
rahzan
The cvf DLL has a questionable routine wrapped in a execption catching c-wrapper. Is there a way to export the c-wrapper to the outside world also?
yes, another cvf "wrapper" can wrap the c-wrapper and I know how to export that, but that trick is altogether too ugly.
Will appreciate any hints.
Tim
Jugoslav_Dujic
Valued Contributor II
Should be possible. Either use _declspec(dllexport) in the code (immediately after type-spec), or create a .DEF file and add it to your project:
EXPORTS
MyCWrapper = _MyCWrapper@40
where the former is exported name (as in ALIAS) and the latter is mangled name.
Jugoslav
rahzan
Thank you,
__declspec(dllexport)
is the way to go.
gfthomas8
Jugoslav is right but indulge me, please, what do you expect to achieve by exporting the wrapper?
Ciao,
Gerry T.
rahzan
It is a means to directly calling an otherwise exported routine in the DLL (from the outside) with exception catching protection.
Tim
