Unable to have .lib compiled
Diego_S_2
Hi !!
We have an old Fortran 6A source code in Italy.
We have visual studio 2013 installed on windows server 2008 R2 64 bit.
But.. We cannot compile Fortran... no error.. no .lib if I biuld a project ... !!!!!!!
If I try to build the solution I get some errors like this one :
Error    6    error LNK1181: cannot open input file 'C:\Users\RIDP425\Desktop\Ver_3.0.3.0_Marzo_2016\Fortran\prg\Lib_aux_curve\Debug\Lib_aux_curve.lib'    C:\Users\RIDP425\Desktop\Ver_3.0.3.0_Marzo_2016\Fortran\prg\main_analisi_statistica\LINK    main_analisi_statistica
I explain ->
We purchased intel composer 2016 version 2 and installed on visual studio 2013 update 5 .
We then loaded the solution with visual studio 2013 .
When I compile a basic project gives no error and gives us the build complete message but under the Debug folder does not appear any librart.lib ... why?
But If I try to build the solution I get the above list of errors "error  LNK1181" ????
Why the project that biuild does not give us a .lib project ?
Why we get some
LNK1181 errors ?
if I use compiler Command PROMPT 10.1 I get some errors (LNK2019 and LNK1120):
libifcoremt.lib(for_main.obj) : error LNK2019: unresolved external symbol _MAIN_
_ referenced in function _main
77curve_aux_adi.exe : fatal error LNK1120: 1 unresolved externals
Someone very nice give us a tip please !!
Many thanks !!
DEBORA_P_
Here the whole project.
Thx so much
You didn't select "All configurations" before changing the properties. Select the Debug configuration and make the same changes I suggested above.
DEBORA_P_
ooooooooooookkkkkkkkkkkkk! finally
========== Build: 0 succeeded, 0 failed, 37 up-to-date, 0 skipped ==========
thx a lot!!!!!!!!!!
DEBORA_P_
''Visual studio cannot debug because a debug target has not been specified''
what means?
It means the executable project has no EXE specified in the Debugging > Command property. This is usually $(TargetPath) which combines the Output Directory, Target Name and Target Extension properties from the General page. It could also be that you don't have the executable project selected as the "Startup Project" - this is indicated by the project name being shown in bold font in the Solution Explorer pane. If that's the case, right click on the executable project and select "Set as startup project".
DEBORA_P_
The program '[4208] main_accoppiamento.exe' has exited with code 1 (0x1) -main accoppiamento
dll_analisi_statistica.dll doesn't exist on your computer- main analisi statistica
The program '[6568] main_curve_unita.exe' has exited with code -1073741510 (0xc000013a)..main_curve_unità
The program '[432] dinamica.exe' has exited with code -1 (0xffffffff).main_dinamica
The program '[8800] main_regressione.exe' has exited with code 1 (0x1).main_regressione
The program '[8288] simcent.exe' has exited with code -1 (0xffffffff).main_simcent
The program '[6220] stazionario.exe' has exited with code -1 (0xffffffff). main_stazionarioNW
regressione isn't an exe file-main_regressione
this happens when I select the "Startup Project". The other ones It says aren't .exe.
If I set $(TargetPath) project to project ....nothing!
So now you have a different problem in that a DLL that your executable needs isn't where Windows is looking for it. Copy that DLL into the folder with the EXE.
DEBORA_P_
in the folder with the exe dll_accoppiamento exist yet :-(
DEBORA_P_
This comment has been moved to its own thread
