29487 Discussions
Unable to integrate Intel® Parallel Studio XE Composer Edition for Fortran Windows*and Visual Studio
avadh__kumar
I have just bought and installed Intel Parallel Studio XE 19 and have been trying to integrate it with Microsoft Visual Studio 19  https://visualstudio.microsoft.com/thank-you-downloading-visual-studio/?sku=Professional&rel=16.
After installing both I tried to follow steps mentioned in https://software.intel.com/en-us/get-started-with-parallel-studio-xe-cluster-for-windows.
How do I write the following command in command prompt
1. From a command prompt or script, cd to <install_dir>/parallel_studio_xe_2019.<update number>.<package number>\bin
How do i find out the package number
Steve_Lionel
Ignore that document - it is a poorly-worded attempt to describe how to use the compiler from the command line.
Instead look at https://software.intel.com/en-us/articles/installing-microsoft-visual-studio-2019-for-use-with-intel-compilers
Make sure that the Intel version you have is at least Update 4 (Compiler 19.0.4). Update 5 was released a few days ago.
