We have build many FORTRAN x32 DLL's utilizing VS2008 and Intel(R) Visual Fortran 11.1.038.
When we try "upgrade" to x64 we always get the following error when attempting to build:
Build Log
Build started: Project: test, Configuration: x64|x64
Output
Compiling with Intel(R) Visual Fortran 11.1.038 [Intel(R) 64]...
ifort /nologo /iface:cvf /module:"x64\x64\\" /object:"x64\x64\\" /libs:static /threads /c /Qvc9 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin\amd64" "E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\UG_NUFORM_DLL.for"
Compiling manifest to resources...
rc.exe /fo "E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.dll.embed.manifest.res" "E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.dll.embed.manifest.rc"
Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
Copyright (C) Microsoft Corporation. All rights reserved.
Linking...
Link /OUT:"x64\x64\test.dll" /NOLOGO /MANIFEST /MANIFESTFILE:"E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.dll.intermediate.manifest" /IMPLIB:"E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.lib" "x64\x64\UG_NUFORM_DLL.obj" "E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.dll.embed.manifest.res"
Link: executing 'link'
Creating library E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.lib and object E:\AST_SOFT\Soft_dev\Solid\UniGr\UG_Nuform\test\x64\x64\test.exp
libifcoremt.lib(for_main.obj) : error LNK2019: unresolved external symbol MAIN__ referenced in function main
x64\x64\test.dll : fatal error LNK1120: 1 unresolved externals
test - 2 error(s), 0 warning(s)
The following is the simple subroutine that is the sole member of the project/DLL:
Subroutine UG_NUFORM_DLL [dllexport] (ArgsIn) !DEC$ ATTRIBUTES ALIAS:'UG_NUFORM_DLL' :: UG_NUFORM_DLL !DEC$ ATTRIBUTES STDCALL :: UG_NUFORM_DLL !DEC$ ATTRIBUTES REFERENCE :: ArgsIn C C (c) A. S. Thomas, Inc. 2006 C All rights reserved. C C ======================================================= C C The program translates UG file into C LEVEL I and LEVEL II outputs C C ======================================================= IMPLICIT NONE ! character*256 ArgsIn ! character*256 command_line common /cmd_line/command_line ! !=================================================================================== !==================================================================================== command_line=ArgsIn return C END
This test DLL builds when built using x86.. What is necessary to get a working DLL?
I expect to see the /DLL option in the link command, but it's not there. I don't see anything obvious in the project file you posted (though I did ask for it to be attached as a file.) If I take this project file it builds fine with VS2008 and the oldest compiler I have, 12.1.
All I can suggest is to add /DLL to Linker > Command Line > Additional Options and see what happens. I see that this project references a separate library - what happens if you remove that from the Linker > Input property page? (Since it doesn't seem to be used.) I doubt this makes a difference, however.
How did you do this "upgrade"? It looks to me as if the project is not set as a DLL project type. Please attach the .vfproj file from this project so I can see what the project settings are.
<?xml version="1.0" encoding="UTF-8"?>
<VisualStudioProject ProjectType="typeDynamicLibrary" ProjectCreator="Intel Fortran" Keyword="Dll" Version="11.0" ProjectIdGuid="{B322A008-C53D-4854-80C0-5EE106ED94EE}">
<Platforms>
<Platform Name="Win32"/>
<Platform Name="x64"/></Platforms>
<Configurations>
<Configuration Name="Debug|Win32" ConfigurationType="typeDynamicLibrary">
<Tool Name="VFFortranCompilerTool" SuppressStartupBanner="true" DebugInformationFormat="debugEnabled" Optimization="optimizeDisabled" Interfaces="true" WarnInterfaces="true" CallingConvention="callConventionCVF" Traceback="true" BoundsCheck="true" RuntimeLibrary="rtMultiThreadedDebugDLL"/>
<Tool Name="VFLinkerTool" SuppressStartupBanner="true" GenerateDebugInformation="true" SubSystem="subSystemWindows" LinkDLL="true" AdditionalDependencies="$(AST_SOFT)\soft_image\string_dec\release\string_dec.lib"/>
<Tool Name="VFResourceCompilerTool"/>
<Tool Name="VFMidlTool" SuppressStartupBanner="true"/>
<Tool Name="VFCustomBuildTool"/>
<Tool Name="VFPreLinkEventTool"/>
<Tool Name="VFPreBuildEventTool"/>
<Tool Name="VFPostBuildEventTool"/>
<Tool Name="VFManifestTool" SuppressStartupBanner="true"/></Configuration>
<Configuration Name="Release|Win32" ConfigurationType="typeDynamicLibrary">
<Tool Name="VFFortranCompilerTool" SuppressStartupBanner="true" RuntimeLibrary="rtMultiThreadedDLL"/>
<Tool Name="VFLinkerTool" SuppressStartupBanner="true" SubSystem="subSystemWindows" LinkDLL="true"/>
<Configuration Name="x64|Win32" ConfigurationType="typeDynamicLibrary">
<Tool Name="VFFortranCompilerTool" SuppressStartupBanner="true" CallingConvention="callConventionCVF"/>
<Tool Name="VFLinkerTool" SuppressStartupBanner="true" AdditionalDependencies="$(AST_SOFT)\soft_image\string_dec\x64\string_dec.lib"/>
<Tool Name="VFMidlTool" SuppressStartupBanner="true" TargetEnvironment="midlTargetAMD64"/>
<Configuration Name="Debug|x64" ConfigurationType="typeDynamicLibrary">
<Configuration Name="Release|x64" ConfigurationType="typeDynamicLibrary">
<Configuration Name="x64|x64" ConfigurationType="typeDynamicLibrary">
<Tool Name="VFLinkerTool" SuppressStartupBanner="true"/>
<Tool Name="VFManifestTool" SuppressStartupBanner="true"/></Configuration></Configurations>
<Files>
<Filter Name="Header Files" Filter="fi;fd"/>
<Filter Name="Resource Files" Filter="rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe"/>
<Filter Name="Source Files" Filter="f90;for;f;fpp;ftn;def;odl;idl">
<File RelativePath=".\UG_NUFORM_DLL.for"/></Filter></Files>
<Globals/></VisualStudioProject>
We are building the x64/x64 configuration.
Adding the /DLL to the linker command line solved the problem for building the x64 variant. We are surprised that such is present in the x86 variant.
Thank you
