It happened again....
This time I have included everything that was in the two project folders.
Also included the RSA3.EXE that was built, that it couldn't start.
Hope you can find something here - the program runs fine when it doesn't
hang after the build step.
Curious - are you able to run the EXE without a rebuild?
Well, it was in DEBUG config, so probably not - - -
Bill,
I'm left with the conclusion that something on your system is corrupting the executable. If I simply relink your existing objects, using the same linker and libraries you are, I get an executable that is oddly different. The things I note are:
- The size of initialized data in your EXE is reported as twice the size of mine, though the actual image sections for initialized data are the same
- A dump of the headers reports the entry point in my EXE to be _mainCRTStartup, but in yours it shows blank
- My EXE has a .rsrc image section of size 1B4 (hex) while yours is size zero (there should not be a zero-sized image section.)
This could be a virus, or it could be a hardware problem, or maybe something else. In any event it does not seem to be the compiler (since I can run the EXE I build by relinking your objects). Supporting this is your earlier comment that sometimes it works and sometimes it doesn't.
Yes, I sometimes get that same message, even though it runs when it's in the same directory where I built it.
It's as if moving it around corrupts it somehow.
What happens when you build it in the release configuration?
Perhaps so, but I still don't see why I can rebuild the same EXE and run it again with no problem.
If it was a hardware problem, then rebuilding the EXE would always give the same result.But about 9 times out of 10, the EXE runs without any difficulty.
Plus - I don't experience any mysterious problems of this type when running other programs.
I did an experiment where I rebuilt the same EXE, and it checks against the problem EXE,
identically bit for bit. But - why would it be different?
I ran Spyware Doctor to check for viruses, and it couldn't find anything. I'm wondering if there is a newvirus that it wouldn't know about (?)
Can you suggest a way to find out what process (if any) is attaching the EXE when I try to run it?
This is where Remote Assist might turn something up, since it's in MY environment that the problem occurs.- Mark as New
