29252 Discussions
Unallocated array in rhs of assignment
John4
Valued Contributor I
Hi, is the following code standard conforming?
[fortran]integer, allocatable :: array(:)
array = [array, 1, 2]
array = [array, 3]
print *, array
end[/fortran]
I mean, does the standard allow an unallocated array to be part of an array expression? Compiling with /stand and /assume:realoc_lhs doesn't issue any warning, and there's no runtime error either.
IanH
With /check:all and 11.1.065 I see an appropriate runtime error.
mecej4
Beyond the scope of your question, if what you wanted to do was to build up the array in pieces, code such as this may be considered:
[fortran]program talloc
  if(.not.allocated(array))allocate(array(0))
  array = [array, 3]
  print *, array
end program talloc
[/fortran]
John4
I'm actually trying to avoid having to check the allocation status every time one entry needs to be added. I already have a subroutine that does just that:
[fortran]subroutine expand(array, idx, istat)
    integer, allocatable, intent(INOUT) :: array(:)
    integer, intent(OUT) :: idx, istat
    integer, allocatable :: aux(:)
    integer :: sz
continue
    idx = -1
    if (ALLOCATED(array)) then
        sz = SIZE(array)
        call MOVE_ALLOC(array, aux)
        allocate (array(1:sz + 1), STAT = istat)
        if (istat /= 0) then
            call MOVE_ALLOC(aux, array)
            return
        endif
        array(:sz) = aux
        sz = sz + 1
        deallocate (aux, STAT = istat)
    else
        sz = 1
        allocate (array(1), STAT = istat)
        if (istat /= 0) return
    endif
    idx = sz
end subroutine[/fortran]
That's why I only asked if it was standard conforming. IanH's answer seems to confirm that the code is illegal.
Les_Neilson
Valued Contributor II
if (allocated(array)) then
sz = size(array) +1 ! new size
allocate(aux(sz), stat=istat)! allocate bigger array
if (istat == 0) then ! ok ?
aux(1:sz-1) = array ! then copy old values tobigger array
aux(sz) = 0 ! initialise new elements
call move_alloc(aux, array)!"rename" aux as array
endif
else
endif
only need one move_alloc and don't need a deallocate
Les
John4
If you look carefully, you'll notice that the second MOVE_ALLOC is applied only in case of error (which is highly unlikely). The explicit deallocation of aux is just a precaution (since some compiler flags might affect automatic deallocation).
Les_Neilson
Ah. OK
Les
