Hi, is the following code standard conforming?
[fortran]integer, allocatable :: array(:) array = [array, 1, 2] array = [array, 3] print *, array end[/fortran]I mean, does the standard allow an unallocated array to be part of an array expression? Compiling with /stand and /assume:realoc_lhs doesn't issue any warning, and there's no runtime error either.
With /check:all and 11.1.065 I see an appropriate runtime error.
Beyond the scope of your question, if what you wanted to do was to build up the array in pieces, code such as this may be considered:
[fortran]program talloc integer, allocatable :: array(:) if(.not.allocated(array))allocate(array(0)) array = [array, 1, 2] array = [array, 3] print *, array end program talloc [/fortran]
I'm actually trying to avoid having to check the allocation status every time one entry needs to be added. I already have a subroutine that does just that:
[fortran]subroutine expand(array, idx, istat)
integer, allocatable, intent(INOUT) :: array(:)
integer, intent(OUT) :: idx, istat
integer, allocatable :: aux(:)
integer :: sz
continue
idx = -1
if (ALLOCATED(array)) then
sz = SIZE(array)
call MOVE_ALLOC(array, aux)
allocate (array(1:sz + 1), STAT = istat)
if (istat /= 0) then
call MOVE_ALLOC(aux, array)
return
endif
array(:sz) = aux
sz = sz + 1
deallocate (aux, STAT = istat)
else
sz = 1
allocate (array(1), STAT = istat)
if (istat /= 0) return
endif
idx = sz
end subroutine[/fortran] That's why I only asked if it was standard conforming. IanH's answer seems to confirm that the code is illegal.
if (allocated(array)) then
sz = size(array) +1 ! new size
allocate(aux(sz), stat=istat)! allocate bigger array
if (istat == 0) then ! ok ?
aux(1:sz-1) = array ! then copy old values tobigger array
aux(sz) = 0 ! initialise new elements
call move_alloc(aux, array)!"rename" aux as array
endif
else
endif
only need one move_alloc and don't need a deallocate
Les
endif
else
endif
Les
If you look carefully, you'll notice that the second MOVE_ALLOC is applied only in case of error (which is highly unlikely). The explicit deallocation of aux is just a precaution (since some compiler flags might affect automatic deallocation).
Ah. OK
Les
Les
