Unary vs binary overloaded operator
_helvio_
Hi again,
I am trying to overload the minus operator (-) with two procedures, one defining a subtraction of two objects. and the other defining the negative of a single object:
[fortran]MODULE scalars
   IMPLICIT NONE
   ! Access
   PRIVATE
   PUBLIC :: oldscalar
   PUBLIC :: OPERATOR(-)
   ! Parent type
   TYPE :: oldscalar
      COMPLEX :: a
   CONTAINS
      PRIVATE
      PROCEDURE :: eq_sca
      GENERIC, PUBLIC :: ASSIGNMENT(=) => eq_sca
   END TYPE oldscalar
   ! Overloaded operator
   INTERFACE OPERATOR(-)
      MODULE PROCEDURE neg_sca
      MODULE PROCEDURE sub_sca
   END INTERFACE OPERATOR(-)
CONTAINS
   ! Negative
   PURE ELEMENTAL FUNCTION neg_sca(u) RESULT(w)
      CLASS(oldscalar), INTENT(in) :: u
      TYPE(oldscalar) :: w
      w%a = -u%a
   END FUNCTION neg_sca
   ! Subtraction
   PURE ELEMENTAL FUNCTION sub_sca(u, v) RESULT(w)
      CLASS(oldscalar), INTENT(in) :: u, v
      w%a = u%a - v%a
   END FUNCTION sub_sca
   ! Convenient assignment for extensions of TYPE(oldscalar)
   PURE ELEMENTAL SUBROUTINE eq_sca(u, v)
      CLASS(oldscalar), INTENT(out) :: u
      TYPE(oldscalar) , INTENT(in)  :: v
      u%a = v%a
   END SUBROUTINE eq_sca
END MODULE scalars
MODULE fields
   USE scalars
   IMPLICIT NONE
   ! Extended type
   TYPE, EXTENDS(oldscalar) :: newscalar
   END TYPE newscalar
   ! Yet another new type
   TYPE :: scalarfield
      TYPE(newscalar), ALLOCATABLE :: site(:)
      !TYPE(oldscalar), ALLOCATABLE :: site(:)
   END TYPE scalarfield
      MODULE PROCEDURE sub_matf
CONTAINS
   ! Subtraction
   PURE ELEMENTAL FUNCTION sub_matf(A, B) RESULT(C)
      CLASS(scalarfield), INTENT(in) :: A, B
      TYPE (scalarfield) :: C
      C%site = A%site - B%site
   END FUNCTION sub_matf
END MODULE fields[/fortran]
This code fails to compile with the Intel Fortran Compiler 12.1.5,  returning the following error message:
mod.f90(78): error #6549: An arithmetic or LOGICAL type is required in this context.   [SITE]
mod.f90(78): error #6355: This binary operation is invalid for this data type.   [SITE]
compilation aborted for mod.f90 (code 1)
However, it compiles successfully if either I
  1. comment out line 21, i.e. dropping out the unary operation, or
  2. replace line 63 with line 64, i.e. using the parent type instead of the extended type
but I need to use the extended type. Am I doing something wrong?
_helvio_
I believe this is a compiler bug. I have escalated it as issue DPD200235328 and will update this thread when I have any news.
This error has been fixed in the compiler sources.  I expect the fix to appear in an update in the October timeframe.
